Tributo all'Alpina B3S
Discussione in 'BMW Serie 3 E90-E91-E92-E93' iniziata da Gio72, 29 Agosto 2011.
  1. lorenzo 61
    8.218
    798
    3 Ottobre 2006
    M4 C
    Un risultato notevole visto che il maggior distacco ai punti viene accumulato in una voce che sembra significare assistenza alla guida o cose simili.
  2. AR147
    AR147 Presidente Onorario BMW
    18.430
    6.687
    7 Maggio 2005
    Torino
    520d G31 LCI
    Si esattamente.
  3. lorenzo 61
    8.218
    798
    3 Ottobre 2006
    M4 C
  4. lorenzo 61
    8.218
    798
    3 Ottobre 2006
    M4 C
    Certo sarei curioso di sapere cosa dice il tizio tedesco, quali sono i suoi giudizi.
    Una cosa è certa , che la vecchia 4x4 gira su quel pistino come la nuova BrumbrumcarM2 dagli interni tristi come il veleno.
  5. lorenzo 61
    8.218
    798
    3 Ottobre 2006
    M4 C
  6. lorenzo 61
    8.218
    798
    3 Ottobre 2006
    M4 C
    BMW M5 VS Alpina B5: a very close comparison test by Autocar UK.
  7. lorenzo 61
    8.218
    798
    3 Ottobre 2006
    M4 C
    Alpina has always kept a respectful distance from the products of
    BMW’s M division, despite a relationship with BMW that is far closer than most imagine and involves far more than knocking out 1700 factory-approved cars every year.
    Alpina exists within the very fabricof BMW, with an entire other side to the business dedicated to developing the manufacturer’s own products on projects as diverse as the suspension for the 2 Series Active Tourer and the powertrain of the Dakar Mini. Remember the thundering V8 in the old BMW X5 4.8iS (and, indeed, the brand new Morgan Plus 8)? We have Alpina to thank for its existence.
    But you only need to look at the spec box to know that with its new B5, Alpina is no longer feeling so coy about treading on the toes of its in-house rival. Indeed, so close is it to the new M5 in almost every regard, it appears to be something closer to a kick in the shins. While wearing steel-capped boots.
    However, does it not seem inherently implausible that this new B5 will have what it takes to hobble BMW’s masterly new M5? Alpina is so small that it will make fewer than 500 B5s over the next year of which just 18 have been allocated to the UK. Of those 18 at least 10 will be estates, which means no more than eight of these B5 saloons will be sold here in the next 12 months. Mastery of the mighty M seems something of an ask.
    Except that on the way to our Welsh rendezvous, it felt like it just might be possible. I have long been a fan of the considered and understated Alpina approach – but accepted too that thrill-seekers would always and understandably have their heads more readily turned by the output of BMW’s M division. But this one felt different. At times the engine it has created for itself – similar to but by no means the same as the almost identically powerful M5 unit – barely feels turbocharged at all, so seamlessly does it deliver its punch across such a wide rev range. Were it not for its cultured but quiet soundtrack, this could a seven-litre naturally aspirated engine.
    But even at its best, it serves mainly as facilitator and factotum for a chassis that picks up the already outstanding characteristics inherent within its 5 Series underpinnings, and sprints into the distance. So despite the liquorice-thin sidewalls of its tyres and the monster footprints they support, the B5 offers an implausibly sumptuous ride, better by far than, say, that of the previous generation 7 Series limo. Together with the seamless transition of power available from the eight-speed ZF transmission, the B5 presents just about the most sophisticated supersaloon ever to head to the hills.
    Which is where it finds the M5 lying in wait for it. And even on first acquaintance, it looks like the Alpina upstart is going to get mugged. BMW has done a pretty well judged job in pumping up the appearance of the M5 without making it look like a hot-rod. It’s only when you park it next to a car as subtle as the B5 and see that jutting jaw and beefy side skirts that it starts to look slightly steroidal.
    It’s an impression the interior makes no attempt to dispel. While the Alpina cabin is clearly that of a 5 Series reclothed in exquisite upholstery that doesn’t sit quite as comfortably with its electric blue dials as you might hope, the M5 cockpit is a breed apart. Instead of discreetly concealing its many set-up functions in electronic sub-menus like the B5, the M5 not only has many more, it puts them front and centre.
    There are individual buttons that control mapping for the steering, suspension and powertrain, a selector that allows you to choose how aggressively the M5 changes gear and, of course, two red ‘M’ buttons on the steering wheel that allow fast-track access to your tailored set up options. And while a part of me thinks the approach is, as Jeeves might say, a trifle sudden, a rather larger, unreconstructed chunk of me finds it all frightfully exciting and makes me want to go driving right away. And good though the Alpina’s cabin is, it never quite does that.
    So you climb aboard the M5, aim it up the road and invite it to do its thing. The next thing that happens is that the thunderous reply from the V8 is joined by a new and alien sound that appears to be emanating from you. It largely takes the form of expletives. Now, I have no idea why this should be, given that both cars are so close in power, torque, weight, share the same gearbox and have all but identical acceleration figures, but I can report only as I find. While the B5 can make you feel like you’ve been flung from a catapult, the M5 experience is closer to that of an artillery shell’s. On a dry, smooth, straight road, its tyres momentarily break traction before the electronics chime in even if you leave it in four wheel drive. And then you’re off, bellowing your way towards the horizon. It is utterly thrilling, not least because the engine is so much louder, deeper in voice and sharper-edged too.
    And that’s not the only reason it’s quicker than the Alpina from one place to the next. With tyres two sections wider than the B5’s at the front and one section narrower at the rear, the clear intent here is that the M5 should resist understeer like no other two-tonne tank in history; and it does. Aided by pretty aggressive off-centre steering response, the M5 has an insatiable appetite for apices and, once the nose is in, you can trust its iron body control to ensure the rest will duly follow. Where you guide the Alpina along a great mountain road, you fire the M5 at it because that is the way it insists on being driven.
    Game over for Alpina, then? By no means. The M5’s approach is not without its drawbacks and you don’t need long in the Alpina to appreciate it. For all its extra speed, the M5 is not as relaxing a car to drive fast and you might not think that matters too much. To me it does: a car relaxes you when being driven rapidly because it gives you confidence, and a car that gives the driver confidence is, by my definition at least, a fine handling car. And in three distinct ways, the B5 inspires more confidence than the M5: specifically its steering is more linear, better weighted and, crucially, has more feel. Doubtless it will understeer more and I’m sure that ultimately the M5 has more body control but, on even the quietest public roads, for nearly all people nearly all of the time and in the context of two-tonne saloon cars, the fact that the B5 feels more natural, predictable and reassuring counts for more. It has better brake feel than the M5 on its optional ceramic rotors too.
    But what’s so fascinating about this contest is that having seen the Alpina banging tent pegs into pristine M5 turf, the M5 turns around and repays the compliment in kind. Set everything to its least hyperactive mode, go for a long lollop of the kind for which the B5 exists and you’ll find the M5 does an outstanding impression of a luxury saloon. Its ride is close enough to B5’s that I’m sure some would actually prefer its slightly more controlled gait and, while you can never quite escape the presence of the mighty V8, there will be plenty who will consider the car none the worse for that, myself included. Which is why it is so devilishly hard to choose a winner. I never much liked the previous M5, which was just not a very pleasant car to drive quickly, but this one is improved in every way that matters to me, the least important being the fact that it is faster. What BMW has achieved here is to make the M5 exciting again in a way it has not been since the demise of the gloriously unhinged V10 E60 M5 eight years ago, yet it has done so while also creating a car so usable it recalls the spirit of the E34 M5 of the early 1990s. It really is a superb car.
    But the Alpina is more rounded still, an exquisitely judged car of quite stunning deftness whose appeal, while perhaps less obvious than that of the M5, is no less compelling for that. The essential choice, then, is this: do you go for the car that is more exciting or more satisfying? Were this a sports car comparison, there would a strong case to give the nod to the M5. But these are cars in which people do huge distances, very few of them on roads such as these. So even if you say the M5’s flaws are cancelled by its stronger performance and call it a draw on the open road, the rest of the time the Alpina just has the edge. As good to drive and an even easier car with which to live, it is the B5 that is our winner.
  8. lorenzo 61
    8.218
    798
    3 Ottobre 2006
    M4 C
  9. magnabuffi
    nostalgici
  10. Gabo
    5.804
    appassionati :vamp:
  11. lorenzo 61
    8.218
    798
    3 Ottobre 2006
    M4 C
    I più giovani non sapranno chi è, il Bernard dal cognome impronunciabile.
    Ha seguito il progetto Veyron è stato Ceo della vW ma soprattutto nasce in Bmw diventandone poi l'amministratore delegato:
    ecco un'intervista che potevo inserire solo qui e attenzione a quel che dice nell'ultimo minuto del video.
  12. Gio72
    Gio72 Presidente Onorario BMW
    28.985
    2.941
    3 Giugno 2008
    G80 M3 Competition
    “Let’s face it. Everyone has a vice.
    Mine is cars”
  13. DerrickNAE3
    10.574
    1.259
    30 Luglio 2013
    Fantastiche le Alpina, qualunque modello di qualsiasi epoca, peccato che però non siano ufficialmente importate in Italia...:(
  14. lorenzo 61
    8.218
    798
    3 Ottobre 2006
    M4 C
    Andiamo a far compere in Germania. ;)
    A DerrickNAE3 piace questo elemento.
  15. DerrickNAE3
    10.574
    1.259
    30 Luglio 2013
    Magari!...:mrgreen:Ce l'hai sempre la B3? La cambierai con una nuova?:-k
  16. Gio72
    28.985
    2.941
    3 Giugno 2008
    G80 M3 Competition
    Alpina mi ha sempre affascinato, ma adesso che sono completamente addentro alla “droga M4”, non cambierei manco sotto minaccia.
    Mi sono appena fatto un passo dolomitico a velocità warp e sono ancora eccitato...
  17. DerrickNAE3
    10.574
    1.259
    30 Luglio 2013
    Per me, sarebbe un bel dilemma tra M ed Alpina, preferisco queste ultime per la maggiore esclusività e le finiture interne migliori, però non so se ne valga la pena affrontare i casini di un acquisto in Germania, con pure la perdita della garanzia Best e non stiamo parlando di una serie 1 usata...:-k;)
  18. lorenzo 61
    8.218
    798
    3 Ottobre 2006
    M4 C
    Massimo rispetto e comprensione per le motivazioni di Giovanni che comprendo appieno... e ci mancherebbe...
    sulle garanzie farò un approfondimento ma i due anni canonici ci stanno sicuramente.
    Al momento del primo tagliano feci fare l'estensione a 4 anni /120k km per soli 400,00 euro.
    Sì ce l'ho ancora perché :
    a) la guido da 150.000 km e non mi ha ancora stancato
    b) è setosa o cattiva in base all'angolo della caviglia destra
    c) onestamente cosa compro di meglio ?
  19. lorenzo 61
    8.218
    798
    3 Ottobre 2006
    M4 C
    [​IMG][​IMG]
    A -JoeBlack- piace questo elemento.
  20. lorenzo 61
    8.218
    798
    3 Ottobre 2006
    M4 C
    Buonasera, qui sopra qualche foto estratta dal sito alpina.
    Sono gli ultimi 99 esemplari, della B4S offerti in 5 colorazioni oltre alla favolosa Heritage che replica il logo alpina in uso negli anni 70.
    Anche le caratteristiche di potenza e coppia sono state aggiornate 452 cv e 680 nm di coppia.
    Da mettere in garage subito.
