Post dllo sgrat sgrat .) ancora lei!! maledetta catena
Discussione in 'BMW Serie 1 F20/F21' iniziata da kasdan, 5 Aprile 2014.
  1. kasdan
    kasdan Collaudatore
    498
    7 Settembre 2008
    Bmw 118D F20
    ragazzi vi riporto una direttiva Puma trovata in altri lidi che ci riguarda purtroppo...in relazioni a casi di F20 rumorose e con catena sostituita verificatisi in UK
    PuMA
    Consult measure M
    No measurement Theme
    43863106-09 N47, N47S, N47T, grinding noise in the engine, the timing chain scrapes
    Validation date (dd / mm / yy) Current Status Affiliate
    Validated 14/12/12 FR, VP
    Vehicles involved
    Series E Motor Body
    E60 E61 E81 E82 E83 N47 N47S N47DKO N47T
    E84 E87 E88 E90 E91
    E92 E93 F10 F11 F20
    F25 F30 F31
    Production period (beyond) Comment period Return info (all cases
    (Dd / mrn / yy) production until) (dd / mnn / yy) /
    Complaint
    Engine noise and friction scraping type from 1500 rev / min, perceptible in the cockpit. The noise is noticeable on the gearbox housing or the oil pan.
    Cause
    Sharp edges of the sprockets or the chain does not move regularly on the slides.
    Important measure:
    before starting the repair, ensure the availability of essential items!
    It is necessary to distinguish between three cases:
    case 1:
    for motors N47, N47DKO, N47S, production period from 01.03.2007 to 05.01.2009.
    In case of customer complaint, replace the following components:
    - 11 21 7 803 479 replacement crankshaft with bearing shells.
    Note: Use crankshafts produced after 5. 1. 2009!
    The production date stamped on the crankshaft sprocket (see Appendix, page 1.)
    Meaning of numbers
    - The first two digits indicate the production line.
    - The six digits indicate the year (two digits), month, and day.
    - The last five digits are the serial number of the crankshaft. The crankshaft shown on page 1 of the Annex has been made October 21, 2009.
    - 11 41 7 797 896 chain drive of the oil pump.
    - 11 31 8 506 652 chain below.
    - 13 52 7 797 906 sprocket drive the oil pump.
    - 11 27 7 800 523 gear (intermediate gear for balancing shafts).
    - 11 27 7 802 575 pinion (drive shaft balancing).
    - 11 27 7 802 576 pinion (drive shaft balancing).
    - 11 31 8 510 014 upper chain.
    - 11 31 7 797 899 guide rail for upper timing chain.
    - 13 52 8 573 158 guide rail for timing chain lower
    - 13 52 8 573 159 rail for timing chain tensioner below.
    Note: the lower chain, use only the rails and tensioners guidageamortis! (See Appendix, page 2)
    For greater supply chain, use only the rail without reinforcements! (See Appendix, page 3)
    Note: according tune and repair instructions for the idler lesarbres balancing!
    If the idler gear and balancer shafts are set incorrectly, the engine can produce a crankshaft with nine bruitsmême, etc.. View manual repair 11 21 500 "replacement of the crankshaft."
    Note: On vehicles on which the crankshaft has been replaced under uneréparation previous:
    treat these vehicles as described in "case 2".
    Case 2:
    for motors N47, N47DKO, N47S, N47T period from production of 05.01.2009 - 01.03.2011
    In case of customer complaint, replace the following parts:
    - 13 52 7 797 906 sprocket for driving the oil pump.
    - 13 52 8 573 158 guide rail for lower chain.
    Note: it is not necessary to loosen the bolt on the idler for the arbresd'équilibrage
    Note: the lower chain, use only the rails and tensioners guidageamortis l (see Appendix, page 2)
    Note: On vehicles having already been under repair track without reinforcements and surlesquels both chains have been replaced: treat these vehicles as indicated inparagraph "Case 3).
    Case 3:
    For N47T engine part products from 01.03.2011 and engines already repaired with rails deguidage without reinforcements.
    link alla vicenda
    http://www.babybmw.net/viewtopic.php?f=63&t=45004
    https://www.youtube.com/watch?v=3oWrjdxM6eQ&feature=youtube_gdata_player
    video del difetto
    Ultima modifica di un moderatore: 5 Aprile 2014
  2. 1likenoone
    1likenoone Secondo Pilota
    988
    56
    10 Ottobre 2013
    BMW F20
    La mia ha come sigla motore n47d20k1 quindi non dovrebbe essere coinvolta....
  3. kasdan
    kasdan Collaudatore
    498
    7 Settembre 2008
    Bmw 118D F20
    Quando e' stata prodotta la tua caro?
  4. kasdan
    kasdan Collaudatore
    498
    7 Settembre 2008
    Bmw 118D F20
    Cm se leggi i post del forum inglese ci sono utenti con auto prodotte nel 2013 che hanno lo sfregolio...
  5. kasdan
    kasdan Collaudatore
    498
    7 Settembre 2008
    Bmw 118D F20
    E comunque mi sa che la t sta per una sigla universale non che ci sia una k una c o altro se non erro
  6. kasdan
    kasdan Collaudatore
    498
    7 Settembre 2008
    Bmw 118D F20
    [TABLE=class: wikitable]
    [TR][TH]Engine[/TH]
    [TH]Displacement[/TH]
    [TH]Minimum specific fuel consumption(g/kWh)[/TH]
    [TH]Compression Ratio[/TH]
    [TH]Engine Weight(kg)[/TH]
    [TH]Power[/TH]
    [TH]Torque[/TH]
    [TH]Redline(rpm)[/TH]
    [TH]Injection Pressure(bar)[/TH]
    [TH]Relative Boost(bar)[/TH]
    [TH]MEP(bar)[/TH]
    [TH]Maximum combustion chamber pressure(bar)[/TH]
    [TH]Introduced in[/TH]
    [/TR]
    [TR]
    [TD]N47D16[/TD]
    [TD]1.6 L (1598 cc/98 in³)[/TD]
    [TD][/TD]
    [TD]16.5:1[/TD]
    [TD][/TD]
    [TD]70 kW (95 bhp) @ 4000 rpm[/TD]
    [TD]235 N m (173 lb ft) @ 1500 - 2750 rpm[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]2013[/TD]
    [/TR]
    [TR]
    [TD]85 kW (116 bhp) @ 4000 rpm[/TD]
    [TD]260 N m (192 lb ft) @ 1750 - 2500 rpm[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]2012[/TD]
    [/TR]
    [TR]
    [TD]N47D20[/TD]
    [TD]2.0 L (1995 cc/121 in³)[/TD]
    [TD]198[/TD]
    [TD]16.5:1[/TD]
    [TD]149[/TD]
    [TD]260 N m (192 lb ft) @ 1750 rpm[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]09/2009[/TD]
    [/TR]
    [TR]
    [TD]105 kW (143 bhp) @ 4000 rpm[/TD]
    [TD]300 N m (221 lb ft) @ 1750-3000 rpm[/TD]
    [TD]5000[/TD]
    [TD]1600[/TD]
    [TD]1.5[/TD]
    [TD]19[/TD]
    [TD]170[/TD]
    [TD]03/2007[/TD]
    [/TR]
    [TR]
    [TD]120 kW (163 bhp) @ 4000 rpm[/TD]
    [TD]340 N m (265 lb ft) @ 2000 rpm[/TD]
    [TD][/TD]
    [TD]1800[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]09/2009[/TD]
    [/TR]
    [TR]
    [TD]130 kW (177 bhp) @ 4000 rpm[/TD]
    [TD]350 N·m (258 lb ft) @ 1750-3000 rpm[/TD]
    [TD]5000[/TD]
    [TD]1.5[/TD]
    [TD]22[/TD]
    [TD]180[/TD]
    [TD]03/2007[/TD]
    [/TR]
    [TR]
    [TD]135 kW (184 bhp) @ 4000 rpm[/TD]
    [TD]380 N·m (280 lb ft) @ 1750-2750 rpm[/TD]
    [TD]5000[/TD]
    [TD]1.5[/TD]
    [TD]22[/TD]
    [TD]180[/TD]
    [TD]03/2010[/TD]
    [/TR]
    [TR]
    [TD]16.1:1[/TD]
    [TD]161[/TD]
    [TD]150 kW (204 bhp) @ 4400 rpm[/TD]
    [TD]400 Nm (295 lb ft) @ 2000 rpm[/TD]
    [TD]5200[/TD]
    [TD]2000[/TD]
    [TD]2.0[/TD]
    [TD]25.3[/TD]
    [TD]200[/TD]
    [TD]10/2007[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]16.5:1[/TD]
    [TD][/TD]
    [TD]160 kW (218 bhp) @ 4400 rpm[/TD]
    [TD]450 Nm (332 lb ft) @ 1500-2500 rpm[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]2011
    [/TD]
    [/TR]
    [/TABLE]
  7. kasdan
    kasdan Collaudatore
    498
    7 Settembre 2008
    Bmw 118D F20
    [TR][TH]Engine[/TH]
    [TH]Power[/TH]
    [TH]Torque[/TH]
    [TH]MEP(bar)[/TH]
    [/TR]
    [TR]
    [TD]N47D16[/TD]
    [TD][/TD]
    [TD]16.5:1[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]2013[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]2012[/TD]
    [/TR]
    [TR]
    [TD]N47D20[/TD]
    [TD]198[/TD]
    [TD]16.5:1[/TD]
    [TD]149[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]09/2009[/TD]
    [/TR]
    [TR]
    [TD]5000[/TD]
    [TD]1600[/TD]
    [TD]1.5[/TD]
    [TD]19[/TD]
    [TD]170[/TD]
    [TD]03/2007[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]1800[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]09/2009[/TD]
    [/TR]
    [TR]
    [TD]5000[/TD]
    [TD]1.5[/TD]
    [TD]22[/TD]
    [TD]180[/TD]
    [TD]03/2007[/TD]
    [/TR]
    [TR]
    [TD]5000[/TD]
    [TD]1.5[/TD]
    [TD]22[/TD]
    [TD]180[/TD]
    [TD]03/2010[/TD]
    [/TR]
    [TR]
    [TD]16.1:1[/TD]
    [TD]161[/TD]
    [TD]5200[/TD]
    [TD]2000[/TD]
    [TD]2.0[/TD]
    [TD]25.3[/TD]
    [TD]200[/TD]
    [TD]10/2007[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]16.5:1[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]2011
    [/TD]
    [/TR]
    [/TABLE]
  8. bayl1ss
    bayl1ss Kartista
    222
    24 Marzo 2013
    Ex 147 blackline - 116d
    Scusate l'ignoranza..ma cos'é una direttiva puma?
    comunque speriamo bene...
  9. kasdan
    kasdan Collaudatore
    498
    7 Settembre 2008
    Bmw 118D F20
    è una direttiva che viene emanata in caso di interventi urgenti da BMW in questo caso riguarda ancora il nostro motore n47
  10. Car evo_lution
    Car evo_lution Amministratore Delegato BMW
    2.846
    173
    10 Novembre 2012
    BMW F20 116d 2.0 (MY 2012)
    La mai è stata prodotta il 2 gennaio 2012 e quindi monta N47T .. come ho già detto nel forum ho il problema da quando avevo circa 20k km (quindi circa 10k km fa) .. confermato dalla conce
  11. kasdan
    kasdan Collaudatore
    498
    7 Settembre 2008
    Bmw 118D F20
    Ma che palle ragazzi mamma mia...la mia prodotta 19.11.2011 ma ad ora tutto il 32000 km...
  12. kasdan
    kasdan Collaudatore
    498
    7 Settembre 2008
    Bmw 118D F20
    Car ma in conce non ti sei incazzato a dovere? Possibile che questa maledizione continui?
  13. Car evo_lution
    2.846
    173
    10 Novembre 2012
    Ti dirò che un mese fa la conce ha sistemato anche l'X1 di mio padre .. mi incazzerò a dovere se dovrò uscire con cifre importanti nel caso i problemi si ripresentassero fuori best
  14. kasdan
    kasdan Collaudatore
    498
    7 Settembre 2008
    Bmw 118D F20
    Ma quindi hai già fatto il lavoro?
  15. Car evo_lution
    2.846
    173
    10 Novembre 2012
    Sulla 1er ancora no
  16. kasdan
    kasdan Collaudatore
    498
    7 Settembre 2008
    Bmw 118D F20
    Ma perche non te lo fanno? Io ho chiamato BMW Italia e gli ho detto che la mia è import e che quindi senza best 4 e s caso mai dovesse esserci il problema nonnviglio metterci soldi...mi hanno risposto che se dovesse capitare si valuterà un accordo... Il che mi sa di ammissione del difetto che purtroppo permane ancora
  17. Car evo_lution
    2.846
    173
    10 Novembre 2012
    Perchè sono appena entrato in best e dicono che non è ancora messa così male da fare .. poi se salta tutto sappiamo tutti benissimo che mi ripagano il motore .. cmqe entro anno il lavoro lo faccio fare così poi si va di modulo
  18. kasdan
    kasdan Collaudatore
    498
    7 Settembre 2008
    Bmw 118D F20
    Ha non farti fregare da questi coglioni ...io siero di non avere il problema senno sino cazzi in concessionaria heheheh...ma gli hai chiesto come mai ancora con sto problema?
  19. Car evo_lution
    2.846
    173
    10 Novembre 2012
    Per farla moolto breve dicono che si tratta di componentistica sottodimensionata per le pressioni del motore .. ma capire perchè dal 2007 non siano riusciti/non abbaino voluto risolvere il problema resta un mistero
  20. kasdan
    kasdan Collaudatore
    498
    7 Settembre 2008
    Bmw 118D F20
    Ahahahhah ridicoli
