1. Simone67
    Simone67 Primo Pilota
    1,417
    Mar 12, 2005
    Marostica
    318 c.i.- 996 V2 sbk
    scusate se riapro vecchi topic,ma sono incappato in questo di the riddle
    Instructions to access the hidden OBC functions:
    1. Hold Trip Reset while turning ignition key to On position
    2. OBC should show "Test"
    3. Use Trip Reset to select function 19.0 that unlocks all the
    features
    3. Wait for display to show "Off"
    4. Depress Trip Reset for 1/2 second and release it
    5. With no delay press Trip Reset several times to select one of the
    following function s
    BMW E46 On-Board Computer (OBC) Hidden Codes
    nr example description
    1 Car Engine and cluster data
    1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
    1.1 4nnn K-number
    1.2 690236 Cluster Part #
    1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
    1.4 1200 Week (12)/year of manufacture (2000)
    1.5 09_160 Hardware (09) and software # (16.0) of cluster
    1.6 Not used
    1.7 04__44 CAN-version (04) KI-revision index (44)
    2 (test) Cluster System Test - Acticates the gauge drivers,
    indicators and LEDs to confirm function
    3 SI Data
    3.0 1098 Used fuel in litres since last SI (Service Inspection)
    3.1 0231 Periodic inspection days; elapsed days (since last SI)
    4 Momentary Consumption
    4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
    4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
    5 Distance Gone Consumption
    5.0 082 Average mileage; 082=8.2 liters/100km
    5.1 0536 Calc. km to refuel (momentary distance to go)
    6 Fuel Level sensor inputs in liters
    6.0 109330+ Fuel level averaged; Left half sensor input=10.9
    liters; Right sensor input=33.0 liters
    6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9
    liters
    6.2 0442+ Indicated value (44.2) and tank phase
    7 Temperature and Speed
    7.0 021+ Coolent/Engine temperature (2.1C) koelvloeistof-temp.
    7.1 130 Ambient/Outside temperature - chg met 5 pts.
    125/130/135
    7.2 + Engine speed / Current RPMs 1/min
    7.3 + Vehicle speed / Current Speed in km/hour
    8 Input value in HEX form
    8.0 1d0+ System voltage ADC-Value Hex code
    8.1 26C33C+ ADC Values HG left/HG right
    8.2 0000 ADC Value brake degradation sensor (000=o.k.)
    8.3 18C ADC Value outside temperature
    9 Battery
    9.0 140 Battery Voltage - 140 = UB 14.0v
    9.1 242013+ ?
    9.2 074_78+ ?
    9.3 0011+ ?
    10 Not used
    11 Not used
    12 Not used
    13 GonG Gong Test
    14 Not used
    15 Status cluster I/O-ports (bit codes) 0=low; 1=high
    1st-belt contact, seat belt fastened=0; 2) ignition
    lock contact, key inserted=0; 3) door contact, door open=0; 4) clock
    button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission
    failure=0
    Status Digital Outputs (bits) 0=inactive, 1=active
    1) Gong output; 2) Brake warning lamp; 3) Low fuel
    warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
    16 Not used
    17 Not used
    18 Not used
    19 Lock Status; unlocks functions in range 3-18
    19.0 L-On/L-Off Unlock: press button when "L-Off"
    20 Not used
    21 Software Reset; reset OBC settings
    00 End of test
    ho un po' di timore ad agire ma vorrei essere sicuro di non fare cazzate.
    tradotto:volete dirmi che oltre le 5 funzioni standard si possono attivare anche queste qua sopra???? 8-[ :eek:
  2. RALLYMAN
    15,797
    170
    Feb 11, 2004
    335xi E90 M-Sport+530d Futura
    Ma certamente, se no che lo mettevamo a fare quel topic??? :lol: :mrgreen: :wink:
  3. Simone67
    1,417
    Mar 12, 2005
    Marostica
    beh certo non volevo mettere in dubbio alcunchè,maaa c'è qualcuno l'ha fatto,a cui chiedere bene in dettaglio procedura e funzionalita'?
  4. Simone67
    1,417
    Mar 12, 2005
    Marostica
    hei Rally ma tu l'hai fatta sta cosa???
    ..ma quando capiti da ste parti,fai uno squillo,che mi par di capire che di rally ne mastichi,no?magari per il"CITTA' DI BASSANO"...
  5. b0sh
    b0sh Amministratore Delegato BMW
    4,475
    115
    Feb 1, 2005
    man
    fatto piu e piu volte.
  6. Simone67
    1,417
    Mar 12, 2005
    Marostica
    cosa vuol dire piu' e piu' volte,ogni volta che fai la procedura è fine a se stessa??cioè la devi fare ogni volta???Fammi capire... :-k
  7. piccinino
    7,127
    158
    Aug 17, 2005
    Ex - 330Ci E46
    sì... la procedura la devi rifare ogni volta ... il "dato" ti resta sullo schermo fintanto che non spegni la macchina...
