BMW Serie 3 E90/E91/E92/E93 Nuovo NCS Dummy 0.6.0.9 (UPDATE)
Discussione in 'BMW Fai da te e tutorial: trucchi e consigli' iniziata da bixiomauri, 12 Giugno 2019.
  1. bixiomauri
    4.867
    1.722
    21 Novembre 2016
    Emilia Romagna
    BMW 3 series E90 LCI
    NUOVO AGGIORNAMENTO NEL SECONDO POST.....
    Nuova versione, con data 28\08\2018
    • 0.6.0.8 (2018-08-28)
      • Fixed bug in order options. While reading the *CTV.000 file order options from the "INDIVID" categories were wrongly combined with those from the "GRUPPE" categories resulting into conflicting order options in certain modules.
      • Added ability to empty the FSW_PSW.MAN trace manipulation file from the "Export FSW/PSW" button dropdown menu.
      • The "HEX/DEC" button will now also change the numeral system of length.
      • The default command line argument is now the trace file. It is no longer necessary to provide prefix /tracefile= if you want to load a trace file. For example: NcsDummy.exe "C:\NCSEXPER\WORK\E31-EKM.C25-FSW_PSW.TRC". This makes it easier to use NCS Dummy as default application to open trace files with.
      • Exporting module functions, trace functions and differences will now include groups even when control unit data is not selected.
      • Small number of corrected translations.
    Ultima modifica: 2 Dicembre 2019
    A Thriller piace questo elemento.
  2. bixiomauri
    4.867
    1.722
    21 Novembre 2016
    Emilia Romagna
    Nuova versione rilasciata v. 0.6.0.9 con data 19-09-2019
    0.6.0.9 [release notes]
    • Fixed broken shortcut keys SHIFT+F3 and SHIFT+ENTER to search backwards in the graphical trace editor.
    • Added several new shortcut keys for frequently used operations like loading and saving trace files, changing the numeral system, adding parameters,...
    • Added fullscreen mode for the "Modules and Traces" tab. Click the arrow button in the bottom right corner of the graphical trace editor or press F11 to toggle.
    • Added possibility to add parameters and update modules in trace functions mode. It is no longer necessary to unload the trace file to do so. In addition NCS Dummy will ask to update the module automatically when exporting to FSW/PSW trace files. For clarity context menu items "Add Parameter" and "Add Custom Data" were renamed to "Add FSW/PSW Parameter" and "Add Custom Nettodata" respectively.
    • Added support for portable application. In order to make NCS Dummy save its settings to a file instead of the registry, create an empty text file NcsDummy.ini in the application folder or launch NCS Dummy (once) with command line argument /portable.
    • Added reverse lookup to the Hex Trace Viewer. Placing the cursor on an address location selects the matching element in the graphical trace editor.
    • Added detection for erroneous parameters with identical keywords but different data like in module FRMFA.C10.
    • Added warning dialog when trying to export nettodata changes to an FSW/PSW trace file.
    • Holding ALT or CTRL while clicking the "HEX/DEC" button toggles between hexadecimal and binary (holding SHIFT already did).
    • Restored compatibility with Microsoft Windows 2000. Unsupported. May break again in the future.
    • Small number of new and corrected translations.
