nuova Audi A4
Discussion in 'Auto Europee' started by gimax, Aug 17, 2007.
  1. mamo
    mamo Presidente Onorario BMW
    15,678
    345
    Aug 23, 2004
    M340i Touring
    ecco, perfetto
    auto strafica nel suo segmento
  2. DjMarvel
    DjMarvel Presidente Onorario BMW
    9,626
    1,231
    Dec 28, 2004
    330Cd,e92 30d,F30 30d,G30 30d
    nel complesso è + bella della serie 3
    anche gli interni sono curati
  3. mamo
    15,678
    345
    Aug 23, 2004
    M340i Touring
    sono gli interni della A5 in pratica
    è stupenda, poche balle
    personalmente non credo proprio che preferirei la E90
    A4 3.0TDI Quattro =P~
  4. gimax
    gimax Presidente Onorario BMW
    8,356
    267
    Jun 9, 2006
    135i PK / Cinquino
    non vedo una cippa!!!!! :evil:
  5. El Nino
    18,476
    431
    May 23, 2003
    Scheduled to make its world debut at the upcoming Frankfurt Motor Show, we can finally show you official pictures of Audi’s all-new A4 sedan. At first glance, the car could be mistaken for its predecessor but on closer inspection we can see that it features shorter overhangs up front as well as a longer bonnet and wheelbase. This in effect gives the car more road presence and a much tougher stance when compared with the model it replaces.
    Below the new sheetmetal is where Audi engineers have focused most of their attention. The car’s differential has switched places with the clutch (or torque converter for autos), which has made it possible to move the front axle forward by 154mm. This also allowed engineers to move the location of the engine further behind the front axle, giving the car improved weight distribution, which in turn led to better dynamics. Despite sticking with conventional steel-construction for the body the new A4 tips the scales at just 1,410kg for the 1.8L TFSI model.
    The car’s suspension system is totally new and is comprised mostly of light-weight aluminum. Other technical highlights include Audi’s new drive select feature, which can vary response from the engine, gearbox, steering and suspension to suit the driver’s unique preferences. The A4 also gets Audi’s speed-sensitive dynamic steering and fully adjustable damping control of the shock-absorbers.
    The new A4 range will initially be introduced with a choice of five engines, their power outputs ranging from 143hp (105kW) to 265hp (195kW). The four-cylinder petrol engine, like the diesels, is turbocharged, and both types of engine have direct fuel injection. Though no DSG gearbox is available as yet, the A4 will still get three different transmission options. These include a conventional six-speed manual, a tiptronic auto and Audi’s multitronic CVT unit.
    Until the new S4 and RS4 arrive, power-nuts will have to rely on the 3.2L FSI V6 as the most powerful engine in the A4 range. This motor develops 265hp (195kW) and a wide-spread 330Nm (244ft-lb) of torque all the way from 3,000 to 5,000rpm. It accelerates the A4 3.2 FSI quattro with manual gearbox from a standstill to 100km/h in only 6.2 seconds and allows it to reach an electronically controlled 250km/h top speed. The petrol V6 is joined by the smaller 1.8L TFSI, which develops 160hp (118kW) and a torque of 250Nm (185lb-ft) between 1,500 and 4,500rpm. When equipped with the manual box, the 1.8L A4 accelerates to the ton in 8.6 seconds and maxes out at 225km/h. The new turbocharger is a major improvement on the unit used on the outgoing model. At an engine speed of 2,000rpm the turbo sees the engine output 10% more torque than the older unit and 30% quicker as well.
    Diesel fans get treated to three new engines, 240hp (176kW) 3.0L V6 with a peak torque of no less than 500Nm (369lb-ft) arriving from as early as 1,500rpm and hanging around until 3,000rpm. It needs only 6.1 seconds to accelerate to 100km/h from a standing start, and has a top speed of 250km/h. Joining the 3.0L unit is a smaller 2.7L V6 diesel with 190hp (140kW) and 400Nm (295lb-ft) of torque on tap, as well as four-cylinder 2.0L TDI. This engine has the lowest output of the new A4 range, developing just 143hp (105kW) and 320Nm (236lb-ft) of torque. All the diesel offerings outperform the new Euro 5 exhaust emission limits thanks to improved thermodynamics and the latest particulate filters.
    Inside, occupants are treated to more generous legroom than the previous model thanks to the new car’s 2808mm wheelbase. Rear seat passengers get an extra 36mm of knee room, while head and shoulder room have also been increased. Seats are fully adjustable, but electronic control remains an option as does the cushion heater. The cabin is highlighted with either aluminum or wood trim, and the sporty S models come with a unique black interior including the roof-lining. The first cars should hit showrooms in Europe by the end of November with the US and other markets penciled in for early next year.
  6. Goliath
    Goliath Secondo Pilota
    800
    17
    Jul 6, 2007
    Audi TT Roadster / E92 320i
    mah sono un po' perplesso...speravo in qualcosa di più originale. Bellissima per l'amor del cielo, ma bellissima in quanto a5 con 5 porte, e non come nuova a4 imho.
  7. farnci1
    farnci1 Amministratore Delegato BMW
    3,185
    62
    Dec 1, 2004
    linea 37 blu
    nel complesso,tra la nuova classe C e la e90,questa è quella nel complesso riuscita meglio,nessun punto debole,tra design interno ed esterno,aspettando le prove su strada.cmq venderà di brutto,considerando che l'A4 come berlina nn è mai stata il massimo,aspettando poi la station.
  8. mamo
    15,678
    345
    Aug 23, 2004
    M340i Touring
    la station sarà un capolavoro di sicuro
  9. Goliath
    800
    17
    Jul 6, 2007
    la classe C inizialmente mi sembrava un po' troppo rigida nelle forme, ma vista un paio di volte da vicino, e di color nero, mi son ricreduto
  10. mamo
    15,678
    345
    Aug 23, 2004
    M340i Touring
    la classe C è fuori competizione per prestazioni assurde rispetto a E90 e A4
  11. El Nino
    18,476
    431
    May 23, 2003
    Non tutti comprano la macchina pensando alle prestazioni.
    Le Mercedes sono assegni circolari, anche da vecchie. Le BMW e le Audi quando le rivendi ti danno una ca@@ata se è il modello vecchio.
  12. mamo
    15,678
    345
    Aug 23, 2004
    M340i Touring
    certamente ma per un confronto che sia abbastanza omogeneo, le Mercedes stanno fuori perché troppo "lente"
    ormai faccio fatica a credere che esistano "assegni circolari" nell'usato :wink:
  13. gimax
    8,356
    267
    Jun 9, 2006
    135i PK / Cinquino
    se le foto ufficiali sono queste.............................:-k
    http://www.autoblog.it/galleria/audi-a4-2008/1
    Imho è semplicemente un cesso................... :lol:
    salvo solo gli interni....................che come sempre in Audi sembrano di un altro pianeta rispetto a Bmw.
    vedremo la touring.....................e prima di esprimere un giudizio definitivo,aspetto altre foto ed eventualmente di vederla dal vivo..........:-k
  14. El Nino
    18,476
    431
    May 23, 2003
    Io il confronto lo faccio guidandole, dalle sensazioni che mi danno. Poco mi frega se da 0-100 una ci mette 3" e una 3"7....io non ho mai fatto uno 0-100 e non le ho mai tirate a manetta le mie auto :wink:
    Se mai avrai una Mercedes lo proverai di persona! :wink:
  15. mamo
    15,678
    345
    Aug 23, 2004
    M340i Touring
    prezzi?
  16. mamo
    15,678
    345
    Aug 23, 2004
    M340i Touring
    ho capito e sono d'accordo però sai bene che guidare una mercedes non è uguale e nemmeno simile rispetto ad una bmw
    le audi danno un piacere diverso ma non sono addormentate come le mercedes
  17. Bolletta
    10,422
    490
    Apr 26, 2006
    Vari rottami bavaresi®
    un 'a5 a 4 porte :-k
  18. Goliath
    800
    17
    Jul 6, 2007
    mah non so, io personalmente quando compro un'auto lo faccio perchè mi attira esteticamente, poi se ha 200 o 300 cavalli visto che non devo tirare o quanto ci impiega a raggiungere la velocità warp mi importa poco :mrgreen:
  19. gimax
    8,356
    267
    Jun 9, 2006
    135i PK / Cinquino
    magari..................:lol:
  20. mamo
    15,678
    345
    Aug 23, 2004
    M340i Touring
    la classe C Avantgarde è secondo me uno spettacolo davanti
    nera coi cerchi giusti è splendida
    peccato sia un orso
