N/U: Porsche 911 Targa - Prj. 991
Discussione in 'Auto Europee' iniziata da beckervdo, 9 Febbraio 2009.
  1. poliziottesco
    poliziottesco Secondo Pilota
    508
    179
    6 Maggio 2010
    bmw 123d M sport + mazda mx5
    Per dovere di cronaca riporto da autocar prima esperienza a bordo della 991 (attenzione, si parla di esperienza dal sedile passeggero...)
    All-new 911 - first ride
    30 June 2011
    An all new Porsche 911 will be revealed later this year – and Autocar joined the development team in South Africa to sample the car.
    The new 911, codename 991, is only the third all new design in the car’s incomparable 48 year history. The first of the three most critical departures between it and its forebears is that this is the first 911 to be built chiefly from aluminium.
    The second difference is that the wheelbase has been extended by a substantial (but currently secret) amount. Two-thirds of the extra space between the wheels is located behind the driver, although it remains a fundamentally two-seat car. Project manager August Achleitner insists the car’s character and agility have not been compromised.
    But if fiddling with a 911’s wheelbase is courting controversy, changing the way it steers might be seen by purists as punching it in the face. The third reason this 911 is like no other before is that hydraulic power steering has been dropped for an electro-mechanical system.
    Achleitner insists: ‘If you drove this car you would never know it did not have hydraulic steering. Believe me, I know how important this is.”
    The 991 is lighter than the car it replaces by dozens of kilos, despite bigger, heavier wheels, tyres and brakes and more robust crash structures. It’s also very slightly lower.
    But some things have not changed so much. While there is not a single interchangeable part in the suspension, the architectural concept remains the same. You’ll find struts at the front and a multi-link arrangement at the back. Relative spring rates have been slightly increased while the damping has been backed off a little, in pursuit of better small bump isolation. The front track has been widened by a similar amount to that which helped transform the dynamic behaviour of the current 997 GT3 RS.
    Only the powertrain remains familiar, and even here there have been big changes. While the ‘S’ continues to displace 3.8-litres, the standard car’s capacity has been reduced to 3.4-litres. In fact its bore and stroke are identical to those of a Boxster S, though different cams and a new exhaust provide more power – 350bhp at the moment, though homologation has yet to be completed. The power of the 3.8 rises to 400bhp and the rev limit of both engines increases by 200rpm to 7800rpm.
    The PDK double clutch auto has been sharpened up again but it is the manual that might be introduced that breaks new ground. In effect it is a manually controlled single clutch version of PDK which means, for the first time in any manual production car I can think of, seven forward speeds. In fact the first six ratios are identical to the auto, though a slightly shorter, more sporting top gear is fitted.
    The ramifications go far beyond the extra cog. This means the old gearbox is no more, so Porsche’s Motorsport colleagues working on the next generation of GT3s down in Weissach have nothing to strap to the old race-based flat six that’s powered all their cars since 1999. So this noble motor has been retired, presumably to be replaced by the somewhat simpler, cheaper, more modern and unrelated direct injection engine used by all other 911s. Quite what will be done to it for the new GT3 remains to be seen.
    I jump into the passenger seat of the 3.8-litre ‘S’ and exhort Herr Achleitner to drive me back down the mountain as fast as he possibly can. A quick glance around the interior reveals Panamera style and switches, providing a substantial step up in both quality and efficacy from the 997; then he’s off.
    More power and less weight means the old Carrera S’s 0-62mph time of 4.7sec is going to be toast. Porsche hasn’t done the numbers yet, but my money is on 4.5sec for the S and 4.8sec for the 3.4-litre car.
    What I notice is the disconnect between the savagery with which the car attacks each corner and the almost complete tranquillity in the cockpit. What struck me most was how easy it appeared to drive the car on the limit, and how unflappable was its composure.
    It seems to move the game on even from the lofty heights achieved by the 997, but if you’re looking for me to deliver a definitive verdict from the passenger seat, you’re asking the wrong bloke. It was a masterly performance, enough to make me desperate to find out more about what is, clearly, an extraordinary car and, I have little doubt, a great Porsche.
    But is it still a 911? If it is, my sense is that it will be a rather different one – even more capable, usable, spacious, comfortable and quiet. But whether this has been achieved at the expense of some of that magical 997 ability to make you feel hardwired into the road surface, it is simply impossible to say without a steering wheel in your hands.
    fonte: www.autocar.co.uk
    C'e' certezza sul fatto che questa 991 sembrii essere ancora piu' fruibile, spaziosa, confortevole della 997. Che poi il passo allungato e lo sterzo elettromeccanico, assimeme ad aulcune mofdifiche al propulsore possano fare o no la differenza (nel bene e nel male) e' da dimostrare
  2. poliziottesco
    508
    179
    6 Maggio 2010
    In base a quello che si diceva prima da Top Gear and ora da autocar, come peso perde qualcosa e l'allungamento di passo e' dovuto allo spostamento indietro dell'assale posteriore.
    Circa gli interni: belli sono belli, pero', echechezz, aldila' del contagiri centrale non c'e' piu' nulla che richiami quelli classici :sad:
  3. actarus8v
    sul peso, ho appena letto.....e va bene ;) /emoticons/wink@2x.png 2x" width="20" height="20" />
    sugli interni, ribadisco......sono molto belli, ma sembrano più quelli di una ammiraglia che di una sportiva.....e, come dici tu, hanno perso tutti i richiami alla tradizione
  4. docmobile
    3.614
    306
    18 Giugno 2008
    5er...
    Però attenzione perchè il peso non influisce in maniera univoca sulle senzazioni di guida ,influisce invece sui cost idi gestione...che inevitabilmente aumentano.
    NissanGt-r e 997 turbo sono esempi di auto pesanti eppur divertenti e sfaccettate nella guida... e nonostante io sia un"anti-Nissan"ammetto che i suoi 1800kg al volante spariscono.
    Purtroppo non spariscono i consumi smodati,quando si forza il ritmo gli enormi pneumatici e i dischi dei freni mostrano presto il limite di una massa così enorme e si consumano con una velocità imbarazzante soprattutto per il portafoglio.:sad:
  5. beckervdo
    4.517
  6. LUPINN
    5.504
    205
    16 Luglio 2010
  7. beckervdo
    4.517
    In effetti o è una bella burla...o era un primo esemplare..
  8. andreas_ba
    5.073
    362
    28 Dicembre 2010
    VW Lupo
    Sembra una malformazione! >:>
    Ad H no? :vamp:
  9. AleArturo
    4.222
    347
    15 Novembre 2010
    Mini Cooper D
  10. Luigi 123d
    Luigi 123d Presidente Onorario BMW
    5.546
    119
    3 Dicembre 2007
    Boxster S 981
    Una griglia del cambio così sarebbe perfetta... ho letto che è derivato dal PDK, ma anzichè a controllo elettronico c'è la frizione idraulica manuale e la leva del cambio
  11. beckervdo
    4.517
    Su GCF, ipotizzano che il 7 marce manuale venga mosso in modalità sequenziale e non H-Shifter
  12. Masamune
    10.396
    615
    13 Maggio 2007
    Volkswagen Santana 3000
    ...se ciao
  13. AlexMi
    25.820
    2.975
    4 Aprile 2004
    Funny Car
    Promette bene questa nuova 911...
  14. nik82
    nik82 Amministratore Delegato BMW
    2.934
    97
    23 Febbraio 2009
    Alfa Romeo Giulia
    Si si...
  15. beckervdo
    4.517
    Va bhe dai..ha preso fuoco la capotte in tela. Se il collaudatore stesse fumando? :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
  16. AlexMi
    25.820
    2.975
    4 Aprile 2004
    Funny Car
    Ma io parlavo solo di design, quella coda alta non mi dispiace affatto, mi sembra la naturale evoluzione delle classiche linee 911
  17. nik82
    2.934
    97
    23 Febbraio 2009
    Alfa Romeo Giulia
    E io scherzavo...ho colto la palla al balzo perchè avevo leto la notizia 5 minuti prima..
    Non preoccuparti, non te la affibiamo l'icona di gufo del forum.. :mrgreen:
  18. *Alfonso*
    12.583
    2.113
    30 Marzo 2009
    Diverse...
    ...e che cavolo!! e' la seconda che distruggono...tra l'altro la prima con conseguenze mortali per il pilota. :( /emoticons/sad@2x.png 2x" width="20" height="20" />
  19. feb120d
    4.468
    217
    26 Febbraio 2007
    asdasd
    non ti preoccupare che ne son andate perse parecchie, non le vedete tutte...fa parte del giochino!
  20. *Alfonso*
    12.583
    2.113
    30 Marzo 2009
    Diverse...
    :sad:
