MENU SEGRETO BMW X5.... | BMWpassion forum e blog
Discussione in 'BMW X5 E70 / X6 E71' iniziata da Nik-Mo, 6 Dicembre 2005.
  1. Nik-Mo
    Nik-Mo Aspirante Pilota
    38
    6 Dicembre 2005
    QUALCUNO INTERESSATO?
    VI SPIEGO COME FUNZIA?
    :razz:
    NIK
  2. gizmolibero
    gizmolibero Aspirante Pilota
    7 Dicembre 2005
  3. cimbro
    cimbro Kartista
    89
    19 Settembre 2005
    4.4I
    Re: MENU SEGRETO BMW X5....
    Interessato, spiega pure, grazie
  4. Nik-Mo
    38
    6 Dicembre 2005
    PER ACCEDERE AL MENU' SEGRETO:
    E' CARINO, TI DA LA VELOCITà EFFETTIVA, LA TEMP REALE DELL'ACQUA, LA TENSIONE BATTERIA ETC
    The Check Control in the instrument cluster of the current BMW 5/7series hides somes secrets. Here is the procedure how to unveil them and how to unlock the system to get access to all tests:
    Turn ignition to pos. II
    Push right button in the instrument cluster and keep it pushed. You will first see "Check Control OK", some seconds later you will see "Test Nr.01"
    Push the left button on the instrument cluster to see the car's identification number. Add the 5 digits together and write down that number, you will need it for unlocking all the functions. Example: DG23278 will lead to 2+3+2+7+8 = 22
    Push the right button until you see "Test Nr.19"
    Push left button until you see the number that is equal to the one you calculated above
    Push right button again
    Now you will have unrestricted access to Test No.3-21. If you made an error in the procedure mentioned above, Test No.3-21 will only display Lock:ON
    Most of the tests are self-explaintory, and here is a first listing (as far as I can recall):
    1. Display Car's identification number, HW/SW version, date of construction
    2. A very beautiful instrument test
    2. Current consumption (liters/100 km)
    3. Current consumption (liters/hour)
    4. Average consumption (liters/100 km)
    5.Current range
    6. N/A
    7. Average fuel in tank (liters)
    8. Current Speed (kph)
    9. System voltage at Term. "R" (Battery Voltage)
    10.Country/Language (US, Spa, Ger, Jap, etc.)
    11. Units am/pm
    12. Average Speed
    13. ETA
    14. Date of Software Mask
    15. Production Diagnosis
    16. ""
    17. Display Vehicle Specific Data
    18. Alarm Changeover (cont. vs. intermittent OBC chime)
    19. Lock/Unlock
    20. Correction factor for fuel consumption (nicht ändern!)
    21. Reset all defect codes
    1. several numbers and data
    2. [Dispay Test]
    3. VBR: x,x (liters/hr)
    4. RW-VBR: x,x (liters/100 km)
    5. RW: x (km)
    6. N/A 7. TMTL: x,x (liters)
    8. V: x (kph)
    9. UB: xx,xx (V)
    10. LAND: 2=USA, 3=I, 4=E, 5=J, 6=F, 7=CDN, 8=AUS/GOLF, 0=D, 1=GB
    11. EINHEIT 1: B3, B4, B5, B6, B7, B8, B9, BA, BB, BC, BD, BE, BF, B0, B1
    EINHEIT 2: [similar to above, I didn't want to mess with it]
    12. VANK: xx,x (kph)
    13. ANK:xx:xx
    14. ROM:
    15. DIAG: 01 01 000 E3
    16. PORT: 01 101010000, 02 101010000, 03...etc
    17. PROM: 00 12, 01 37, 02 18, 03 E6, 04 02, 05 B3, 06 FF, 07 7E
    18. HORN: DTON or [DTON flashing]
    19. LOCK: ON
    20. KVBR: 1000
    21. RESET?
    :lol:
  5. pelvix
    pelvix Collaudatore
    479
    22 Febbraio 2006
    è che qualche anima pia lo traduce in italiano?
    Non ci capisco un fico..
  6. DMX
    DMX Aspirante Pilota
    39
    7 Marzo 2008
    BMW X5 Smart
    Il Controllo Controllo nel grappolo di strumento del BMW 5/7series corrente nasconde somes secrets. Ecco la procedura come svelarli e come aprire il sistema per arrivare accesso a tutte le prove:
    Si rivolga ignizione a pos. II
    Spinga bottone corretto nel grappolo di strumento e tenga spinse. Lei vedrà "Controllo Controllo OK" prima, alcuno secondo più tardi Lei vedrà "Prova Nr.01"
    Spinga il bottone sinistro sul grappolo di strumento per vedere il numero di identificazione della macchina. Sommi le 5 cifre e scriva quel numero, Lei avrà bisogno lo per aprire tutte le funzioni. Esempio: DG23278 condurrà a 2+3+2+7+8 = 22
    Spinga il bottone corretto finché Lei vede "Prova Nr.19"
    Spinga bottone andato via finché Lei vede il numero che è uguale a quello Lei calcolato sopra
    Spinga di nuovo bottone corretto
    Ora Lei avrà accesso senza restrizioni per Esaminare No.3-21. Se Lei facesse un errore nella procedura menzionata sopra di, la Prova No.3-21 esporrà solamente Lock:ON
    La maggior parte delle prove sono stesso-explaintory, ed ecco un primo listato (come lontano come io posso ricordare):
    1. il numero di identificazione di mostra Macchina, versione di HW/SW, data di costruzione
    2. una prova di strumento molto bella
    2. il consumo corrente (liters/100 km)
    3. il consumo corrente (il liters/hour)
    4. il consumo medio (liters/100 km)
    5.Current serie
    6. N/A
    7. combustibile medio in serbatoio (i litri)
    8. la Velocità corrente (il kph)
    9. tensione di sistema a Termine. "R" (Batteria Tensione)
    10.Country/Language (Stati Uniti, Terme Ger, Jap ecc.)
    11. Am/pm delle unità
    12. Velocità media
    13. ETA
    14. Data di Software Maschera
    15. Diagnosi di produzione
    16. ""
    17. Mostra Veicolo gli Specifici Dati
    18. Allarme Conversione (il cont. il vs. OBC intermittenti suonano in modo armonioso)
    19. Lock/Unlock
    20. Fattore di correzione per il consumo di combustibile (nicht ändern!)
    21. Azzeri tutti i codici di difetto
    1. molti numeri e dati
    2. [Dispay Test]
    3. VBR: x,x (il liters/hr)
    5. RW: x (il km)
    6. N/A 7. TMTL: x,x (i litri)
    8. IL V: x (il kph)
    9. UB: xx,xx (il V)
    10. TERRA: 2=USA, 3=I, 4=E, 5=J, 6=F, 7=CDN, 8=AUS/GOLF, 0=D, 1=GB
    11. EINHEIT 1: B3, B4, B5 B6, B7 B8, B9 LAUREA DI PRIMO GRADO, BB AC, BD, SIA, BF, B0, B1
    EINHEIT 2: [simile a su, io non volli importunarlo]
    12. VANK: xx,x (il kph)
    13. ANK:xx:xx
    14. ROM:
    16. PORTO: 01 101010000, 02 101010000 03... ecc
    18. CORNO: DTON o [DTON che balena]
    19. SERRATURA: SU
    20. KVBR: 1000
    21. AZZERI?
  7. X5MANIAC
    X5MANIAC Kartista
    164
    18 Ottobre 2008
    320d e91, golf V 105 cv
    Sbaglio o la temperatura dell'acqua non cè?
  8. Pao
    Pao Collaudatore
    437
    10 Ottobre 2008
    X5 G05 2019
    Ehi non esiste una roba simile per i parametri della radio dell' x3... così forse riesco a capire perchè l'rds sulla mia macchina non funziona ](*,)!
    Grazie in anticipo a tutti
  9. *Giobbe*
    7.096
    388
    30 Dicembre 2007
    nuovamente BMWizzato...
    sempre da lì, se non ricordo male, si può impostare la visualizzazione delle mappe in 3d............:cool:
  10. 11del
    11del Kartista
    89
    25 Dicembre 2004
    Bari
    330d/530d/x5/z3 /320d
    scusate ma una volta sbloccato come si fanno a vedere i nuovi dati??
  11. X5MANIAC
    X5MANIAC Kartista
    164
    18 Ottobre 2008
    SCUSA MA SE NON SBAGLIO LA TEMPERATURA ACQUA NON Cè......
  12. zeusbimba
    zeusbimba Secondo Pilota
    777
    10 Settembre 2007
    330d f31 sport
    Una volta sbloccato, col pulsante destro cerchi e con quello sinistro selezioni, per esempio la temperatura dell'acqua è il numero 7, quella dell' olio la 17, la velocita (reale infatti differente da quella segnata dal contakm del cruscotto) la numero 8.:rolleyes:
  13. zeusbimba
    777
    10 Settembre 2007
    330d f31 sport
    La temperatura dell' acqua è al numero 7.In questi giorni con la lancetta a metà, nel display mi segna 75 C°
  14. X5MANIAC
    X5MANIAC Kartista
    164
    18 Ottobre 2008
    Susa ma al numero 7 non dice quantità media di carburante nel serbatotio???:wink:
  15. zeusbimba
    777
    10 Settembre 2007
    330d f31 sport
    No, il 7 mi d'ha la temperatura dell'acqua, il 6 la quantità di carburante
  16. 11del
    11del Kartista
    89
    25 Dicembre 2004
    Bari
    Grazie ho risolto!
