M6 hurricane cs
Discussione in 'BMW ///M POWER' iniziata da dieselteox, 5 Maggio 2009.
  1. dieselteox
    5.557
    857
    1 Marzo 2007
    520xd - mini one 5p
    Creating the ultimate BMW, nothing less was the set target for the G-POWER engineers when they started to designe the G-POWER M6 HURRICANE CS.
    The starting basis for this project is the currently most exclusive model in the BMW product range, the BMW M6. Due to the combination of this fantastic basis with the technical innovative products of G-POWER, it was able to create a sports car of superlatives. Powered by a V10 SK III RS twin-supercharger engine with 750 hp / 552 kW, which enabled the G-POWER world record car to achieve a top speed of 367,4 km/h, the G-POWER M6 HURRICANE CS has got what it takes to be a member of the super car league.
    Further characteristics of the G-POWER M6 HURRICANE CS is the multipart widebody kit, the high performance Carbon-Ceramic break system, the individually adjustable suspension kit and last but not least the nifty 21 inch G-[COLOR=blue! important][COLOR=blue! important]POWER [COLOR=blue! important]wheels[/COLOR][/COLOR][/COLOR] with MICHELIN tyres.After the G-POWER M5 HURRICANE RS broke the world record for the fastest sedan, G-POWER developed this idea to use this potential to build the world’s fastest BMW coupe, the G-POWER M6 HURRICANE CS.
    For this project, the redesigned twin supercharger system of the world record car for the fast-revving V10 was used. Compared to the standard system, both belt-driven ASA T1-313 superchargers, each providing charge air for one cylinder bank, were replaced by larger ASA T1-316 models. They have the capacity to increase the volume of charge air by up to 25 percent but only a fraction of that was utilized in this engine. The air volume these chargers are capable of would theoretically be sufficient for a rated power output in excess of 900 hp. The pre-compressed air from both superchargers is cooled for maximum power yield in a dual-flow water-to-air intercooler painted G-POWER orange. This sophisticated cast-aluminum component replaces the stock airbox above the engine. Because of its close proximity to the engine it produces the same instant throttle response as the production engine, albeit with considerably more torque.
    The inner workings of the ten-cylinder four-valve engine are optimized with forged high-performance pistons from Mahle that reduce compression. They have been precisely matched for weight and are much stronger than their production counterparts. The production piston rods and pins also had to make way for special components that can handle the much higher forces.
    Further optimized mapping of the engine electronics also contributes to the increased power output of 750 hp / 552 kW, available between 7,500 and 8,000 rpm. The engine delivers its peak torque of 800 Nm at 5,000 rpm. The G-POWER M6 HURRICANE CS sets new performance records not just for top speed with more than 370 km/h. With sprint times of less than 4.4 seconds from rest to 100 km/h, 9.6 seconds to 200 km/h and 26 seconds to 300 km/h the nearly two-ton coupe is at the head of the pack in these categories as well.
    Two tons and a top speed of 370 km/h naturally place extreme demands on the tires, which were mounted on G-POWER light-alloy wheels. Technology partner Michelin provided high-performance Pilot Sport PS2 tires in sizes 255/35 ZR 19 in front and 305/30 ZR 19 on the rear axle. These tires were the only ones capable of handling the extreme stress. In everyday driving the G-POWER M6 HURRICANE CS runs on 21-inch Silverstone Diamond wheels with size 255/30 ZR 21 and 295/25 ZR 21 tires, due to the capacity of the tires the top speed has to be limited to 340 km/h, than.
    In addition to the most powerful [COLOR=blue! important][COLOR=blue! important]BMW [COLOR=blue! important]engine[/COLOR][/COLOR][/COLOR] ever to power a street-legal BMW, favorable aerodynamic properties were of elementary importance. The needed body kit has to fulfill to function at once. First of all it has to generate enough down force to keep the G-POWER M6 HURRICANE CS on the ground at speeds of more than 300 km/h and secondly it responsible for transform the standard BMW M6 into a super sports car. That is why G-POWER designed a unique widebodykit made entirely from carbon fibre. In addition to producing the desired downforce it is also designed to supply much more cooling air. It consists of front apron, bonnet with vents, [COLOR=blue! important][COLOR=blue! important]rocker [COLOR=blue! important]panels[/COLOR][/COLOR][/COLOR], wheel arche attachments, rear aprons with diffusor and a rear spoiler wing.
    At the same time G-POWER puts the BMW M6 on a diet and makes it [COLOR=blue! important][COLOR=blue! important]lose [COLOR=blue! important]weight[/COLOR][/COLOR][/COLOR] bit by bit. The biggest share is taken by the G-POWER complete exhaust system made entirely form titan which lets the dynamic back pressure drop just like the weight. 24 kg are saved compared to the standard exhaust system.
    In the vehicle interior G-POWER switches the standard front seats against racing seats made from carbon fibre, which ensure a perfect support for the drive in its fight against the centrifugal forces. Of course these seats are lighter than the standard seats as well and again the M6 has lost 24 kg.
    Weight neutral, but not without effects is the G-POWER suspension package CLUBSPORT. It optimizes the road handling of the G-POWER M6 HURRICANE CS to perfection and is consisting of the continuously height-adjustable G-POWER coil-over RS suspension with nine selectable settings each for bound and rebound and the G-POWER anit-roll-bar kit for front and rear axle.
    The option list of the G-POWER M6 HURRICANE CS ends with a true highlight: a Carbon-Ceramic break system with 6-piston calibres and brake discs with 380 mm in diameter. This heavy duty brake system delivers declaration rates beyond the gravity on a constant rate and at the same time are 50% lighter than the standard brakes.
    The standout cockpit of the G-POWER M6 HURRICANE CS features a speedometer with 400-km/h scale, clear-coated carbon-fiber panels for dash, [COLOR=blue! important][COLOR=blue! important]center [COLOR=blue! important]console[/COLOR][/COLOR][/COLOR] and doors, as well as an ergonomically shaped G-POWER sport steering wheel with especially pleasant perforated Kjerba Nappa leather.
    The G-POWER M6 HURRICANE CS can be ordered as a complete car starting at 360.000 Euros.
    source : G-power Press
  2. dieselteox
    5.557
    857
    1 Marzo 2007
    520xd - mini one 5p
    Ultima modifica di un moderatore: 5 Maggio 2009
  3. Attabus
    Attabus Primo Pilota
    1.167
    24
    3 Marzo 2006
    E90 325i
    pauuuuuuura!!
  4. Fra335
    Fra335 Amministratore Delegato BMW
    3.341
    182
    17 Maggio 2007
    Biella
    530d xDrive F11 LCI M-Sport
    [YOUTUBE]http://www.youtube.com/watch?v=dtAPyoBC-bw&feature=related[/YOUTUBE]
  5. Pizzodrift
    8.175
    268
    7 Aprile 2008
    X5 e70, Santa Fe, 320 e36
    :eek::eek::eek::eek::eek::eek:
    Devo portare il 316 compact da questi tizi...
    Tra l'M5 e adesso l'M6 fanno paura =P~
  6. *Giobbe*
    7.096
    388
    30 Dicembre 2007
    nuovamente BMWizzato...
    ...sarà pure "accreditata" di qulache milione di hp.....ma.....mamma mia se è brutta!!
  7. *fefe84*
    4.356
    502
    11 Febbraio 2008
    auto aperitivo infangata
    l'accelerazione nel video...
    gli apre il cofano!!!
  8. freestyle
    freestyle Secondo Pilota
    809
    15
    15 Ottobre 2007
    330xd M - 335i M - Ktm950Smr
    :eek:
  9. briosqui
    briosqui Collaudatore
    359
    7 Luglio 2008
    M3 E92 \ Piper PA28
    spettacolo! Chissà quanto dura l'Essemmeggi con tutta quella coppia
  10. brutale68
    brutale68 Amministratore Delegato BMW
    3.231
    94
    29 Maggio 2008
    TASSATA!!
    doppio.... :eek::eek:
  11. Andrea81STI
    Andrea81STI Collaudatore
    422
    26 Novembre 2008
    M3 e92
    però
  12. freestyle
    809
    15
    15 Ottobre 2007
    Ma riguardando bene il video non notate che impiega circa 7 secondi da 0 a 100 km/h di cui 5 resta ferma a 70/80 km/h.....problemi di cambiata ????? 8-[ ............... :mrgreen:
  13. diddi
    diddi Secondo Pilota
    561
    13 Settembre 2007
    330 XD Touring E91
    si ho notato anche io un imputamento e poi perchè la setitmna lampeggia ed il volante a 370 quasi non ha vibrazioni!?!?!??!?!?
    maaa
  14. Boa
    2.911
    85
    17 Novembre 2008
    :eek: 372?!!!!:shocked!::shocked!:
  15. -mauri-
    -mauri- Amministratore Delegato BMW
    2.517
    170
    16 Maggio 2005
    Rottami vari.
    Ruote posteriori che slittano e sensore del contakm sul cambio magari?
    :mrgreen:
  16. freestyle
    809
    15
    15 Ottobre 2007
    Questo del sensore sul cambio non lo sapevo.... resta comunque il fatto che con quella potenza se dovevano fare il video almeno fatelo bene con un' accelerazione degna di tutti quei puledri "dichiarati".... ci mette quasi 7 secondi da 0 a 100 !!!!!!
  17. Roger84
    17.151
    906
    22 Novembre 2004
    Fà ridere il fatto che questa a 350km, fà i fari alla Enzo che nn ha +!:mrgreen:8-[
  18. photostyle
    photostyle Kartista
    113
    26 Marzo 2009
    fiat punto
    0_0 ci avrà messo 7 secondi ma 5 è stata bloccata per slittamenti vari...e poi da 100 a 300 ci ha messo il tempo che io passo da 100 a 140 :D sticazzi che mostro
  19. Davide-Z
    Davide-Z Direttore Corse
    1.794
    84
    11 Aprile 2007
    Gpz900r & 550- Z1000 06
    stava decollando, per questo ci ha messo troppo per i 100.. non riusciva a ritirare il carrello :D
    STICAZZI!
  20. DAVIDE 73
    DAVIDE 73 Amministratore Delegato BMW
    2.902
    114
    22 Febbraio 2009
    330 XD E91
    bel mostro , non c'è che dire .
    Rimane da vedere come se la cavera' in pista . Per me un'M3 come quella di Nic , con gli angoli giusti , un pelo di centralina , gomme e freni ad hoc , se la magna alla prima curvetta :mrgreen:
