M47N2/N47 "The Mule": maps/moduli/IC/filters/oils/BTscan/trattamenti
Discussion in 'Meccanica ed elettronica BMW' started by Head, Sep 1, 2009.
  1. Davide
    25,219
    484
    Apr 20, 2004
    130i E87
    Ah ecco, mi avevi fatto prendere un accidente :mrgreen:
  2. AR147
    AR147 Presidente Onorario BMW
    17,195
    5,957
    May 7, 2005
    Torino
    520d G31 LCI
    Non vorrei diventare scemo, ma qui cosa c'è scritto?
    Castrol Edge __________________________________ SAE 5W-30 __ Castrol Limited
    Castrol Edge Formula RS _______________________ SAE 0W-40 __ Castrol Limited
    Castrol Edge Sport ____________________________ SAE 0W-40 __ Castrol Limited
    Castrol Edge Turbo Diesel _____________________ SAE 0W-30 __ Castrol Limited
    Castrol Formula RS ____________________________ SAE 0W-40 __ Castrol Limited
    Castrol Formula SLX Turbo Diesel ______________ SAE 0W-30 __ Castrol Limited
    Castrol GTX MAGNATEC __________________________ SAE 5W-30 __ Castrol Limited
    Castrol GTX 9 Magnatec ________________________ SAE 5W-30 __ Castrol Limited
    Castrol SLX LL-04 _____________________________ SAE 0W-30 __ Castrol Limited
    Castrol SLX Longlife III ______________________ SAE 5W-30 __ Castrol Limited
    Castrol SLX Professional OE ___________________ SAE 5W-30 __ Castrol Limited
    Castrol SLX Professional Powerflow BMW LL04l __ SAE 0W-30 __ Castrol Limited
    Castrol SLX Professional Powerflow BMW LL04l __ SAE 5W-30 __ Castrol Limited
    Castrol SLX Professional Powerflow C3l ________ SAE 0W-30 __ Castrol Limited
    Castrol SLX Professional Powerflow C3 TD_______ SAE 0W-30 __ Castrol Limited
    Castrol TXT LL-04 _____________________________ SAE 5W-30 __ Castrol Limited
  3. Davide
    25,219
    484
    Apr 20, 2004
    130i E87
    Che ce ne sono due tipi :mrgreen:
  4. AR147
    17,195
    5,957
    May 7, 2005
    Torino
    520d G31 LCI
    Ma lo 0w30, visto che sono tutti e due LL04, non dovrebbe essere meglio del 5w30?
  5. Davide
    25,219
    484
    Apr 20, 2004
    130i E87
    Non lo so, io so che consigliano lo 0W30 per il 163cv e il 5W30 per il 177cv, altro non so...](*,):mrgreen:
  6. AR147
    17,195
    5,957
    May 7, 2005
    Torino
    520d G31 LCI
    Ottimo anche perchè comunque, da ignorante, credo che non sbagliamo nè con uno nè con l'altro, per cui se te sai che per il 177cv consigliano quello, metti quello, buono a sapersi ;)
  7. Davide
    25,219
    484
    Apr 20, 2004
    130i E87
    Si di questo sono supersicuro!
    Ma la differenza è che il 5W30 è leggermente più "denso" rispetto allo 0W30, giusto?
  8. AR147
    17,195
    5,957
    May 7, 2005
    Torino
    520d G31 LCI
    In teoria, il 0w30 è da consigliarsi maggiormente in presenza di climi freddi. La viscosità a 100°C invece è identica per entrambi gli olii, dato che entrambi sono con indice di viscosità 30.
  9. Davide
    25,219
    484
    Apr 20, 2004
    130i E87
    Ok! Comunque oggi sono andato a prendere il filtro olio in BMW (22,50€), e ordinato 6kg di LL04 a 7,50 cad.
  10. Davide
    25,219
    484
    Apr 20, 2004
    130i E87
    Ho fatto un casino, quello che avevo trovato io è il TXT, non l'SLX.
    E' il TXT LongLfe 04 5W30. Quindi non va bene?
  11. AR147
    17,195
    5,957
    May 7, 2005
    Torino
    520d G31 LCI
    Va bene lo stesso, anche se le caratteristiche sono inferiori. Sinceramente mi sembrava strano, infatti, che costasse così poco. Verifica solo che sia adatto per la tua vettura in quanto non ho idea se vada bene per le auto dotate di DPF.
  12. Davide
    25,219
    484
    Apr 20, 2004
    130i E87
    Eh infatti..trovo le info nel libretto tagliandi?
  13. Davide
    25,219
    484
    Apr 20, 2004
    130i E87
    Ok, non ci capisco più niente.
    Il venditore mi ha detto che ha anche l'SLX Longlife04, lo vende a 8,20 al kg.
    Ma dice che è 0W30, non 5W30............#-o:lol:
  14. AR147
    17,195
    5,957
    May 7, 2005
    Torino
    520d G31 LCI
    Si, non ricordo se in quello dei tagliandi o in quello uso e manutenzione, in uno dei due comunque.
    Ti ricordi ieri sera, quando dicevo 0w30 SLX LL04? Ecco perchè....
    Comunque Luca Mondello (Ice71 su questo forum) per le nostre già a suo tempo aveva consigliato proprio il Castrol SLX LL04 0w30. Secondo me andresti sul sicuro. Controlla il libretto intanto....
  15. Davide
    25,219
    484
    Apr 20, 2004
    130i E87
    Adesso vado a controllare, se va bene gli ordino subito lo 0W30
  16. docmobile
    3,614
    304
    Jun 18, 2008
    5er...
    Oh Davide...un amico di mio cuggino cambiando il suo olio con il wkqyxwwkk34256748yy ha girato al ring in 8:25 con il 320d tutto originale.....io ci penserei....:mrgreen::mrgreen:
    Ok,ok !!già sò dove devo andare....:redface::lol:
  17. Davide
    25,219
    484
    Apr 20, 2004
    130i E87
    Dai dammi il numero di tuo cuggggggggggino che provo a sentire dove l'ha preso :mrgreen:
    Poi vado da una persona a far controllare la pressione...#-o:lol:
  18. Head
    Head Presidente Onorario BMW
    16,085
    752
    May 11, 2005
    E91 Futura S.G.
    Appena arriva il CR6, facciamo la rullata MODULO ON e la rullata MODULO OFF, con V-Power Diesel, e vediamo come stiamo messi.
    Per la cronaca, ho fatto anche il cambio olii completo (motore+additivo, cambio+additivo, diff.+additivo)
    Nessun sostanziale cambiamento.
    Però mi sento più sicuro (magasgrattonatadipalle!!!)
    Ho anche l'additivo nell'I/C.
    In primavera faccio il cambio liquido completo.
  19. giu320coupè
    8,225
    720
    Dec 6, 2008
    cytherea
    nel radiatore vuoi dire?:wink::D
  20. Head
    16,085
    752
    May 11, 2005
    E91 Futura S.G.
    Si, sorry.
    E' l'abitudine di leggere dell'N54 e su E90post.
    :wink:
