Luci xenon su fendinebbia. Nessuno ha questa modifica?
Discussione in 'BMW Serie 3 E90-E91-E92-E93' iniziata da toro9970, 3 Marzo 2008.
  1. toro9970
    toro9970 Direttore Corse
    1.765
    44
    13 Luglio 2007
    寶馬535ð
    Luci xenon su fendinebbia. Nessuno ha questa modifica O ha messo su delle lampade allo xenon sui fendinebbia?
    quelli originali hanno una luce gialla tipo lumino da morto. Brutti.
    Forse con degli xenon le cose cambierebbero.
    Qualcuno mi sa indicare se l'operazione è fattibile (fabietto?)
  2. toro9970
    1.765
    44
    13 Luglio 2007
    寶馬535ð
  3. toro9970
    1.765
    44
    13 Luglio 2007
    寶馬535ð
    1. Tools I used. 8mm socket, wrench, 2-ton jack, extra light support, aftermarket yellow foglight bulbs.
    Oh yeah, and small hands required. [​IMG]
    2. Lift your car. You don't have to lift it alot if you don't have big head.
    3. Get under the car, Take off all the bolts that the red arrows are indicating.
    Close-up pic of the 3 bolts you can't see.
    One of the "bolt" in the middle is actually a clip. Pull out the middle piece with minus screw driver. real easy.
    Close-up pic of the bolt you have to take off by the fender area.
    4. Pull the air-splitter thingy off.
    5. Pull the whole plastic panel off.
    6. Now you'll see the foglight bulb in place.
    7. Reach for it, and twist the bulb socket off the foglight housing.
    8. Take the socket out, take the bulb out, replace it with new ones.
    9. Place the bulbs you've taken out in a safe place if you plan on using them in the future.
    10. Put the new bulb in. Put the bulb socket back in, the exact same way you took it out but reverse twist.
    11. Reverse process, put everything back in, screw the bolts/clips back in. Enjoy the new bulbs. [​IMG]
  4. toro9970
    1.765
    44
    13 Luglio 2007
    寶馬535ð
    Before (dirty cover, I know):
    After (yeah, yeah... the cover is still dirty):
    So first get below the front bumper and pretty much remove every screw in site (8mm socket). Mine might look a little different since I have the OEM aero kit on. Also note, 3 of the screws are holding a ruber piece on. Those are also removed.
    Make sure the wheel is turned all the way out and in the wheel well remove the nut (10mm).
    There are also 2 more 8mm screws further up in the wheel well, right behind that yellow reflector we all love so much. No picture of those...
    After all those screws are removed, you can pull the cover off, enough to get your hand in to replace the bulb. You can see the bulb in the second picture below.
    Notice there is a pin holding the bulb in. So you need to reach in and remove the connector BEFORE trying to remove the bulb. Pinching the bottom end of the plug will allow you to remove it. Once it's removed, you can turn the bulb to remove it and replace. Remember not to touch the bulb.
    Just reverse the process to get everything back together.
  5. toro9970
    1.765
    44
    13 Luglio 2007
    寶馬535ð
  6. FABIOSLK
    FABIOSLK Secondo Pilota
    771
    15 Aprile 2007
    Bmw...
    Dunque prendendole da questo venditore vanno benissimo e non mi segnalano errore giusto?:wink: Qualcuno di voi l'ha già fatto?
