I fari posteriori che aspettavo...
Discussione in 'BMW Serie 3 E90-E91-E92-E93' iniziata da mojitoclub, 9 Novembre 2008.
  1. mojitoclub
    mojitoclub Secondo Pilota
    943
    22
    26 Gennaio 2008
    Suzuki Gran Vitara Evolution
    Eccoli quà... I "Red Line"... dovrebbe essere peò un DIY
    c'è anche un tutorial per realizzarli (in inglese)....
    Ok, this simple guide will explain how I did it. One thing I have to make clear is that I am "simulating" what I did because my mod on the reverse lights were completed and I am not going to "redo" everything.
    Explanation according to the pictures in sequence.
    1) You need:
    - Red and black tint transparent film. I have used up my black tints so I can't show it.... you get the idea [​IMG]
    - Pair of scissors to cut to sizes
    - A plastic ruler to push water out of adhered surfaces
    - A water spray bottle
    - Penknife to trim edges
    - A lighter to cure edges
    2) Cut the transparent film to size. As long as it covers the entire reverse section, it should be enough
    3) Spray the tail light with water. Ensure that the surface is clean and free from dust/ dirt that may get trapped between adhered surfaces
    4) Spray the "cut out" transparent film with water.
    Attached Images [​IMG] [​IMG] [​IMG] [​IMG]
    [​IMG] pengful View Public Profile Send a private message to pengful Find More Posts by pengful
    #13
    Mod guide part 2
    Now, this next part follows.....
    5) Paste the "watered" transparent tint onto the "watered" tail light. Take the plastic ruler or something flat (preferably not metallic as metals have the tendency to slice the transparent film) to push the water out. Do this throughout the entire surface. You should by now have a nice clean surface covered by the transparent film
    6) Take the penknife and carefully trim the lines. Lots of freehand so make sure you do it slowly. Another thing to note is make sure the penknife is sharp. Break off used tips and use a fresh one.
    7) After you trimmed out the film, use the penknife to cut out about 2-3 mm at the edges. Next, take the lighter and cure the sides to make sure they do not "stick out"
    Repeat the same for the black tint if you want to make it look darker, else you could either leave it white or red (if you really do not want to use the penknife to trim the lines). It is up to you.
    Hope this guide is useful. [​IMG]
  2. aristoweb
    aristoweb Presidente Onorario BMW
    7.393
    19 Luglio 2003
    BMW M3 Coupé E92
    Tutta sta fatica ma non sono meglio i black line?
  3. drugo37
    drugo37 Primo Pilota
    1.161
    18
    28 Settembre 2008
    BMW 330d E93 294cvMASERATI GTS
    Quoto black line!!!!!!!
  4. axl
    axl Kartista
    184
    21 Febbraio 2008
    bmw 320d
    Per mojitoclub:
    hai per caso capito cos'é sto film trasparente color rosso che si vede nella 4° foto e dove va applicato?
  5. mojitoclub
    943
    22
    26 Gennaio 2008
    Credo sia quella carta adesiva che si vede nella prima foto...ma non ci sto capendo un c**** !!!!!
  6. fealfan
    fealfan Kartista
    248
    21 Ottobre 2008
    Bmw 325i coupe
    Ciao a tutti
    Ho una 325i E92 con questi fari:
    http://img134.imageshack.us/my.php?image=faroe92tx4.jpg
    Vedendo sia questo post che altri del forum mi sembra di aver capito che ne esistono una marea di versioni....l'auto è di fine 2006 ma i fari nella foto li ho trovati gia montanti, vi risulta che siano di serie ?
    Vi ringrazio
    Fed.
  7. cheddar
    cheddar Collaudatore
    286
    8 Agosto 2008
    BMW 335d E92
    Quoto.
  8. Davideumegghj
    Davideumegghj Secondo Pilota
    767
    20
    13 Maggio 2008
    ..in Attesa. Ex 320d E91
    Quoto i Blackline e poi non girerei mai con del retino sui fari..credo che alla prima pioggia andrebbero via...e poi ci sarebbero quelle fastidiose bolle
  9. PaoLo_Ct
    5.728
    177
    15 Aprile 2008
    Lo ribadisco che i fari in questione con il bianco imho sono stupendi,ma con il nero meglio andare di black line..Cmq ho seri dubbi che quella carta riesca a resistere con il calore prodotto dalle lampadine..
  10. mojitoclub
    943
    22
    26 Gennaio 2008
    Ci sarebbero anche questi...
  11. mojitoclub
    943
    22
    26 Gennaio 2008
  12. marcello
    marcello Primo Pilota
    1.319
    22 Agosto 2003
    335i e92 space grey
    penso di si, sono uguali ai miei
    Ultima modifica di un moderatore: 10 Novembre 2008
  13. Alerab1
    Alerab1 Kartista
    57
    24 Settembre 2008
    BMW E90 330I
    Ciao a tutti,
    io sulla mia 330i ho i fari come quelli che fa vedere Mojitoclub nella foto di apertura e quindi tutti rossi.
    Tenete presente che me li sono fatti rossi da solo, con un risultato sorprendente e che non mi aspettavo neanche io, senza usare pellicole adesive che sicuramente non reggerebbero caldo ed acqua.
    Vi spiego come.
    Ho acquistato una bomboletta di rosso trasparente per fari (Spray di una nota marca, costo circa 9 Euro).
    In pochi minuti ho smontato dal baule i fari stessi; li ho, per sicurezza, sgrassati con uno dei soliti prodotti atti a questo scopo e poi ho coperto con nastro da carrozziere le parti che non dovevano essere investite dalla vernice rossa. Tra l'altro, lasciando un rettangolino del "vetrino" trasparente della luce retromarcia coperto dal nastro adesivo; così da ottenere un risultato molto simile a quelli che sono ora i fari retromarcia della serie 3 ultimissimo tipo.
    Ultima modifica di un moderatore: 1 Gennaio 2009
  14. markulio
    markulio Presidente Onorario BMW
    5.127
    299
    15 Maggio 2008
    Porsche993 C4,E61 530d M-Sport
    potresti postarci le foto?
    Smontare i fanali è complicato?
  15. axl
    axl Kartista
    184
    21 Febbraio 2008
    bmw 320d
    Avevo pensato anch'io allo spray per fari,infatti l'ho comprato,ma avevo dei dubbi sulla resa.Adesso non ti resta che inserire le foto please
  16. Alerab1
    Alerab1 Kartista
    57
    24 Settembre 2008
    BMW E90 330I
    Inserirò volentieri le foto, ma essendo fuori per lavoro dovrò apettare fine mese prima di potergliele fare e metterle nel forum.
    A presto.
  17. markulio
    5.127
    299
    15 Maggio 2008
    aspetteremo con ansia....
  18. mojitoclub
    943
    22
    26 Gennaio 2008
    Grande Ale! Sei la risposta ai nostri dubbi !!!!
    Riesci a fare un piccole tutorial su come procedere passo passo...
    Appena puoi le foto...
    Grande !!!!
  19. markulio
    5.127
    299
    15 Maggio 2008
    in effetti sta' storia dello spray potrebbe avere una resa maggiore rispetto a quella dell'adesivo. Che voi sappiate per non incorrere in sanzioni bisogna lasciare la porzione "bianca" sulla luce della retro?, nella nuova è veramente molto piccola la fessura.
  20. le voyage
    le voyage Secondo Pilota
    881
    26 Gennaio 2008
    Golf mk6 1.6Tdi Highline ex E90 320d
    interessante sta storia dello spray.........ma come si fa a trovare il rosso giusto e di che marca è sto prodotto...nn vorrei combinare guai....:-k
