elenco codici menù obc | BMWpassion forum e blog
Discussione in 'BMW Serie 3 E46' iniziata da gaetanick, 26 Giugno 2006.
  1. gaetanick
    gaetanick Aspirante Pilota
    37
    14 Ottobre 2005
    Grazie alla procedura trovata qui nel forum sono riuscito a sbloccare le varie funzioni nascoste del bc nella mia 320d.
    Volevo conoscere le funzioni di ogni singolo numero (es. 1:codici motore, 2: test spie ecc.)
    Grazie.
  2. RALLYMAN
    15.798
    170
    11 Febbraio 2004
    335xi E90 M-Sport+530d Futura
    Se la ritrovo te la posto... :surprised:
  3. fr4nk
    fr4nk Collaudatore
    410
    19 Aprile 2006
    320d e46 restyling
    nr example description
    1 Car Engine and cluster data
    1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
    1.1 4nnn K-number
    1.2 690236 Cluster Part #
    1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
    1.4 1200 Week (12)/year of manufacture (2000)
    1.5 09_160 Hardware (09) and software # (16.0) of cluster
    1.6 Not used
    1.7 04__44 CAN-version (04) KI-revision index (44)
    2 (test) Cluster System Test - Acticates the gauge drivers,
    indicators and LEDs to confirm function
    3 SI Data
    3.0 1098 Used fuel in litres since last SI (Service Inspection)
    3.1 0231 Periodic inspection days; elapsed days (since last SI)
    4 Momentary Consumption
    4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
    4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
    5 Distance Gone Consumption
    5.0 082 Average mileage; 082=8.2 liters/100km
    5.1 0536 Calc. km to refuel (momentary distance to go)
    6 Fuel Level sensor inputs in liters
    6.0 109330+ Fuel level averaged; Left half sensor input=10.9
    liters; Right sensor input=33.0 liters
    6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9
    liters
    6.2 0442+ Indicated value (44.2) and tank phase
    7 Temperature and Speed
    7.0 021+ Coolent/Engine temperature (2.1C) koelvloeistof-temp.
    7.1 130 Ambient/Outside temperature - chg met 5 pts.
    125/130/135
    7.2 + Engine speed / Current RPMs 1/min
    7.3 + Vehicle speed / Current Speed in km/hour
    8 Input value in HEX form
    8.0 1d0+ System voltage ADC-Value Hex code
    8.1 26C33C+ ADC Values HG left/HG right
    8.2 0000 ADC Value brake degradation sensor (000=o.k.)
    8.3 18C ADC Value outside temperature
    9 Battery
    9.0 140 Battery Voltage - 140 = UB 14.0v
    9.1 242013+ ?
    9.2 074_78+ ?
    9.3 0011+ ?
    10 Not used
    11 Not used
    12 Not used
    13 GonG Gong Test
    14 Not used
    15 Status cluster I/O-ports (bit codes) 0=low; 1=high
    1st-belt contact, seat belt fastened=0; 2) ignition
    lock contact, key inserted=0; 3) door contact, door open=0; 4) clock
    button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission
    failure=0
    Status Digital Outputs (bits) 0=inactive, 1=active
    1) Gong output; 2) Brake warning lamp; 3) Low fuel
    warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
    16 Not used
    17 Not used
    18 Not used
    19 Lock Status; unlocks functions in range 3-18
    19.0 L-On/L-Off Unlock: press button when "L-Off"
    20 Not used
    21 Software Reset; reset OBC settings
    00 End of test
    Ciao
  4. gaetanick
    37
    14 Ottobre 2005
    grazie mille.
  5. m-power
    m-power Secondo Pilota
    597
    3 Giugno 2006
    Bmw 320d
    Funziona davvero?
  6. RALLYMAN
    15.798
    170
    11 Febbraio 2004
    E perchè non dovrebbe? :lol:
