E91 touring zone
Discussion in 'BMW Serie 3 E90-E91-E92-E93' started by ant.o.lantio6, Jan 15, 2011.
Thread Status:
Not open for further replies.
  1. filippo1978
    7,864
    245
    Mar 3, 2011
    320d E91 ///Performance
    Non fare lo spiritoso che te le faccio davvero desiderare se passo da te! ! ! :D /emoticons/biggrin@2x.png 2x" width="20" height="20" /> :D :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
  2. pasquale m
    6,225
    104
    Feb 23, 2010
    bmw 320d m sport step..
    Si ma se avrai già i buchi tondi, io te le do, ma dove le metti:D
  3. filippo1978
    7,864
    245
    Mar 3, 2011
    Il buco tondo si adatta tranquillo! ! ! :D /emoticons/biggrin@2x.png 2x" width="20" height="20" /> :D /emoticons/biggrin@2x.png 2x" width="20" height="20" /> :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
  4. Crocket
    Crocket Direttore Corse
    1,868
    101
    Oct 26, 2008
    e36-e87-e91-e30-f31-z3
    Esatto Black...praticamente hai detto tutto...!!!
  5. pasquale m
    6,225
    104
    Feb 23, 2010
    HiFi Professional LOGIC7 System.
    Experience your music like never before with the HiFi Professional LOGIC7 System. Thirteen speakers ensure high-quality reproduction of all your favourite music from practically any format.
    Seven mid-range speakers, four tweeters and two centrally-positioned woofers ensure an unmatched listening experience in the cabin of your BMW. The tweeters (28 mm in diameter) and woofers (100 mm diameter) feature aluminium membranes. The tweeter uses ceramic components for superb precision.
    Seven mid-range speakers (including one central speaker) are positioned around the cabin: one in each of the front and rear doors, two in the shelf behind the rear seats, one in the centre of the instrument panel. The woofers (217 mm in diameter) are fitted underneath the two front seats.
    The central bass concept enables a symmetrical distribution of the bass frequency output within the vehicle. This concept exploits the underbody volume: the hollow space in the underbody is used to add depth to the bass tones. Positioning the speakers under the seats has the added advantage of freeing boot space, and reducing unwanted vibration of items in the cabin, as well as ensuring excellent, distortion-free bass reproduction.
    The influence of driving noise is automatically compensated by the speed-dependent equalizer, which finely adjusts bass output as required.
  6. pasquale m
    6,225
    104
    Feb 23, 2010
    Ciao simo Complimenti ancora per i led angel, secondo me stanno benissimo! Io non li toccherei piu' ;) /emoticons/wink@2x.png 2x" width="20" height="20" />
  7. filippo1978
    7,864
    245
    Mar 3, 2011
    HiFi Professional LOGIC7 System. Vivi la musica come mai prima con il sistema HiFi Professional LOGIC7. Tredici altoparlanti garantiscono un'elevata qualità di riproduzione di tutta la vostra musica preferita praticamente da qualsiasi formato. Sette altoparlanti mid-range, quattro tweeter e due woofer posizionati centralmente garantiscono un'esperienza di ascolto senza paragoni nella nella vostra BMW. I tweeter (28 mm di diametro) e woofer da 100 mm di diametro) membrane in alluminio. Il tweeter utilizza componenti ceramici per la massima precisione. Sette mid-range (compreso un altoparlante centrale) sono posizionati all'interno dell' abitacolo: uno in ciascuna delle porte anteriori e posteriori, due nel ripiano dietro i sedili posteriori, uno al centro del cruscotto. I woofer (217 mm di diametro) sono montati sotto i due sedili anteriori. Il concetto basso centrale consente una distribuzione simmetrica della frequenza di uscita dei bassi all'interno del veicolo. Questo concetto sfrutta il volume sottoscocca: lo spazio vuoto nel sottoscocca viene utilizzato per aggiungere profondità ai toni bassi. Collocazione dei diffusori sotto i sedili ha il vantaggio di liberare spazio nel bagagliaio, riducendo le vibrazioni indesiderate delle voci nell'abitacolo oltre a garantire eccellenti e senza distorsioni riproduzione dei bassi. L'influenza del rumore di guida viene automaticamente compensato dalla velocità-dipendente equalizzatore, che regola finemente uscita bassi come richiesto.
  8. frenzi
    5,089
    183
    Oct 6, 2010
    quasi quasi....
    anche la mia...sono gia' per la strada :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />:D
    potrebbe essere anche individual...si dovrebbe smontare una portiera e vedere quale tipo di cassa monta....
  9. filippo1978
    7,864
    245
    Mar 3, 2011
    Se non ha il pack individual e' difficile che le casse lo siano, tranne se in post-montaggio! ! ! ! ;) /emoticons/wink@2x.png 2x" width="20" height="20" />
  10. filippo1978
    7,864
    245
    Mar 3, 2011
    Ti ha mandato il codice per la tracciabilita' ? ? ? ?
  11. Max530d
    Max530d Direttore Corse
    2,119
    109
    Jun 11, 2008
    Bmw 320d E90 Lci///M Sport EX 530d E60 M
    Ordinata una nuova scimmia 35€ Simoni racing :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
  12. pasquale m
    6,225
    104
    Feb 23, 2010
    Bella scimmietta ;) /emoticons/wink@2x.png 2x" width="20" height="20" />
  13. filippo1978
    7,864
    245
    Mar 3, 2011
    Bella scimmia ad un ottimo prezzo ! ! ! ;) /emoticons/wink@2x.png 2x" width="20" height="20" />
  14. Max530d
    2,119
    109
    Jun 11, 2008
    Solo che quando me lo monteranno lo faro sfalsare un po' uno dall'altro :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
  15. filippo1978
    7,864
    245
    Mar 3, 2011
    Noi siamo in attesa dello scarico 335 style, altrimenti lo avrei fatto anche io il 330 style! ! ! ;) /emoticons/wink@2x.png 2x" width="20" height="20" />
  16. lele.car
    9,226
    334
    Dec 1, 2009
    BMW Performance
    fatto a Padova
  17. filippo1978
    7,864
    245
    Mar 3, 2011
    Lo so da Stefanob, ma nel caso non si trova qualcosa di piu' vicino si ci va ! ! ! ;) /emoticons/wink@2x.png 2x" width="20" height="20" />
    Qualche fotina no ? ? ? :D /emoticons/biggrin@2x.png 2x" width="20" height="20" /> ;) /emoticons/wink@2x.png 2x" width="20" height="20" />
  18. filippo1978
    7,864
    245
    Mar 3, 2011
    Notte raga ci si sente domani! ! ! ! ;) /emoticons/wink@2x.png 2x" width="20" height="20" />
  19. frenzi
    5,089
    183
    Oct 6, 2010
    ancora no....perche' me lo chiedi??ti son venuti dei dubbi che sia una paccaro?
  20. leo&bmw
    leo&bmw Primo Pilota
    1,335
    20
    May 29, 2009
    E91 177cv attiva
    Azzzzzzzz...io non sono mica tanto lontano peró:lol:
    Qualche reportage del lavoro finito Lele?
    Sai qualcosa di piú...info prezzi...tempo ecc...
Thread Status:
