E che P°°°E !!!! Ho già "fresato" i cerchi !!!!
Discussione in 'Cerchi e Gomme BMW' iniziata da mojitoclub, 23 Ottobre 2008.
  1. mojitoclub
    mojitoclub Secondo Pilota
    943
    22
    26 Gennaio 2008
    Suzuki Gran Vitara Evolution
    ...dopo neanche un mese di cerchi nuovi ho "fresato" alla grande su un marciapiede il mio nuovissimo 17" !!!! Possibile che debba smontarlo per portarlo al carrozziere??? Non esistono altri metodi? Magari fai da te?
  2. Ale_72
    57.838
    23.146
    sfortunatamente non ricordo piu' da dove l'avevo copiato
    REPAIRING WHEEL & RIM SCUFFS & SCRATCHES
    Overview: This article explains how to touch-up minor wheel damage (curb scuffs and scratches) using Wurth Silver Wheel Paint
    Note that although this is a Porsche wheel, the Wurth Silver Wheel Paint is a perfect match for Porsche, BMW, Audi, Mercedes-Benz and some VW wheels. It can also be used to completely refinish any wheel. The following technique, explained in nice detail by "NASAraser of AudiWorld.com", is a good way to do a small area repair if you curb your wheel or otherwise damage a small area.
    Well, there I was, backing into a parking space against a curb. I was in a hurry and I heard it... SCRAPE! One fraction of a second and barely moving. Got out and looked at the rim... OUCH!!!
    As you can see, this is minor wheel damage with very little paint and metal repair required. It could be touched up with a paint touch up stick, but it would not look right. Picture by NASAracer.
    Well, no need to fear. I've done this enough times to have an easy way to do home repairs with a few simple items. Note that this [procedure] only covers light scuffs. This isn't meant to be used to repair a damaged wheel or one where the scuffs cause significant damage to the rim. This is only for those annoying superficial scuffs, which seem to happened to me more times than I care to admit.
    There are plenty of good services which can do this for very reasonable money. Many of you will happily use a service, but I'm inpatient and have the free time (generally) to spend a couple of hours on a repair. Plus, it really takes the edge off "donking" my wheels when I know I can simply fix it myself.
    Here's the parts list you need:
    1. Wurth Silver Wheel Lacquer
    2. Wurth High Gloss Clear Lacquer
    3. Primer
    4. Bondo Spot Putty
    5. 240 and 400 wet & dry sand paper
    6. Paint thinner
    7. Masking tape & masking paper
    I have a can of scratch-filler primer, the Wurth wheel paint and clear (got mine at Performance Products), some paint thinner, Bondo spot putty (or equivalent), sand paper and some 240 and 400 grit sandpaper (if you are REALLY anal, get some 600 grit paper). Picture by NASAracer.
    Clean, Clean, Clean
    This is one of the most important steps. Use paint thinner to thoroughly clean the entire area around the damage. You need to remove all traces of wax and silicones from the surface of the wheel. I'm going to remind you every step of the way to clean. I'll probably end up wiping down these surfaces 10 or more times before painting. If you don't do this, the rest is pointless because the repair will not work. Also, you should only work on the area of the wheel that is damaged. Don't go nuts and try to paint half your wheel on the car. For this technique to succeed we will only sand and paint the immediate area around the damage.
    Use a lint-free cloth for cleaning your wheel. Prior to cleaning with paint thinner (Prepsol is even better), scrub the tire and wheel with dish detergent (Dawn) to remove as much silicone (tire protectant) as possible. Dry thoroughly. Picture by NASAracer.
    Sand and Putty
    I like to start by masking the tire from the wheel. Get the masking tape well behind the rim.Next, [lightly] sand the area to a nice "feather" with 240 grit sandpaper and apply spot putty.
    Important: this entire project will work best if its a nice warm day. The drying time of
    spot putty is minutes but if it's cold or damp, this project is likely to not work out too well. Work in direct sunlight if necessary to keep the work area warm (not hot).
    Remember: keep your sanding to the immediate area around the damage. Trust me on this.
    Use a sanding block (small wood block or rubber erasure) to get the best results. Although dry sanding works, wet sanding is best. Pictures by NASAracer.
    Once you've done the first round of putty, switch to the finer of your sandpaper (400 grit in my case) and sand and putty until it FEELS and LOOKS flush. Note that I use the paper wrapped around a piece of wood to make a flat sanding block. It's best to sand with a flat block to get a smooth, level finish.
    Mask and Primer
    Okay, here's where a bit of laziness is going to create an entirely new project. The silver metallic paint will get everywhere. I'm talking permanently attached to the fender on the opposite corner of the car. Mask carefully and cover the entire car with an old sheet or equivalent.
    I've used the scratch-filler primer and sanded it and put a bit more putty on. Note that this is the first place where I use my special technique. Immediately after I spray the primer (or paint) I clean all of the overspray off the spokes of the wheel (clean rag and paint thinner) and the area around the inside of the rim. I do not want to try to get the paint to smoothly adhere to the entire wheel! We only want to paint the REPAIR. Only the clear coat will be sprayed without wiping off the overspray. Wait for the primer to fully dry and lightly sand it with 400 or 600 grit sandpaper.
    Painting
    VITAL: Read the instructions on the can! If you try to use this paint in cold temperatures (or in damp conditions) it's going to be a mess. Shake the can for at least a full minute and push the spray nozzle as you sweep across and release at the end. Spray on, spray off.
    Spray on, spray off. Apply as a very fine coat. You're not trying to make it glossy. That's the job of the top clearcoat.
    This is roughly the distance I used the can from the wheel. I highly recommend practicing on a scrap part to get used to the distances and thickness this paint sprays. Picture by NASAracer.
    Now we should be nearly done but (as always), Pete got inpatient and sprayed the clear way too soon. As a result, the clearcoat lifted the silver paint and messed up my job.
    This is no biggie. Take a deep breath, get out your rag and the paint thinner and take it all off. The thinner I used did not eat into the primer so I simply cleaned the wheel (again) and re-sprayed the silver paint.
    Here's the paint lifting due to the clearcoat being applied too soon. Be sure to give plenty of drying time. Picture by NASAracer.
    okay, fast forward a few minutes... I had to roll the car forward a bit to keep it in the sun and I had cleaned (and let fully dry) the wheel and RE-sprayed the silver. Now I'm carefully removing the silver overspray. Picture by NASAracer.
    After the silver colorcoat dries (overnight is best), you can apply two thin coats of clear with about 20-30 minutes of drying time between coats. After the clear dries (another day) you can use 1500-2000 grit wet and dry or a fine cut compound to feather in any traces of the repair. Use a final polish to restore full gloss.
    Here's the nicely painted wheel. I let the paint dry overnight before applying the clear coat.Picture by NASAracer.
  3. Lawyer
    Lawyer Direttore Corse
    2.159
    122
    26 Aprile 2008
    Z3 Roadster ed altre Bavaresi.
    Dura la vernice della bomboletta?
  4. Ale_72
    57.838
    23.146
    Non saprei.
    Non l'ho fatto io
  5. samuelet
    samuelet Amministratore Delegato BMW
    3.229
    44
    23 Ottobre 2007
    e91 con turbina
    no! non dura, esperienza personale.
  6. Eagles
    Eagles Kartista
    190
    4 Settembre 2008
    BMW 316i Compact M43
    IO ho usato smalto da donna :D
  7. goldie
    6.755
    859
    26 Aprile 2007
    BMW 430d
    racconta va che io li ho fresati tutti e 4 :sad:, e di smalto da donna ne ho :mrgreen:
  8. Lawyer
    2.159
    122
    26 Aprile 2008
    Infatti lo immaginavo.
  9. Eagles
    Eagles Kartista
    190
    4 Settembre 2008
    I miei (ORRENDI) cerchi originali hanno il segno del tempo, quindi qualche ritocchino l'ho fatto ocn uno smalto da donna color "alluminio", niente di che ma almeno economico :razz:
  10. goldie
    6.755
    859
    26 Aprile 2007
    BMW 430d
    dior è lo smalto che dura di piu e non si scheggia, vedrò se c'è il color cerchi Bmw :lol:
  11. Damiano
    9.005
    388
    19 Agosto 2007
    EX 320ci - 120d MY'09
    io vorrei sapere che stucco è e dove si trova...il colore ha quello da carrozziere e no problem...ma manca lo stucco giusto!
    dai che ho i cerchi invernali come cavia!
  12. antonio54b
    antonio54b Collaudatore
    415
    19 Febbraio 2008
    Messina
    bmw x4 40m
    Li hai fresati sulla gamba che si intravede in avatar? =D>
  13. cheddar
    cheddar Collaudatore
    286
    8 Agosto 2008
    BMW 335d E92
    :mrgreen::mrgreen::mrgreen:
  14. TokyoDrift
    TokyoDrift Kartista
    220
    19 Ottobre 2008
    Lodi
    EX BMW 320d E46M ora wrangler jk
    i Miei cerchi hanno un po' di "sgarbellate" io ho usato della carta vetra medio- fine e poi fine finissima sulla grattata e poi dopo averli lisciati per bene ci passo una pasta argento il metal-cromo,lasci asciugare et voila' un buon lavoro facile e veloce.
  15. KILLER QUEEN
    11.556
    578
    9 Febbraio 2007
    LA CAFFETTIERA.
    vi do una dritta di uno che li fa rifare in fonderia. non costa 20 euro a cerchio come da un carrozza (che per esperienza dopo un anno comincia a sfogliarsi),
    andrete sui 40 a cerchio ma li sabbiano, gli danno 3/4mani di vernice, trattamenti speciali, ecc..in pratica lo rimettono a nuovo.
    molti sanno il mio livello di maniacalita' dell auto.
    e se va bene a me...buona camicia a tutti!
    http://www.maxpianetaruote.com/rigen.swf
  16. Peppe sud
    Peppe sud Secondo Pilota
    542
    30
    3 Aprile 2008
    BMW 130i
    ..grazie, dovrò sperimentare al più presto..purtroppo..
    ..anche se 40 a loro, 30 per spedire e 20 al gommista..
    ..era meglio stare attenti!
  17. mojitoclub
    943
    22
    26 Gennaio 2008
    Mi paice questa manovra... mi sai essere più dettagliato sulla "pasta"? Marca, etc, etc....
  18. TokyoDrift
    TokyoDrift Kartista
    220
    19 Ottobre 2008
    Lodi
    Ciao,la pasta che ti dicevo si chiam "Metalcrom" (della ditta metalcrom di Treviso) c'e' in due colori marrone brunito e' non ci serve o argento che fa al caso nostro.Il tubetto e' tipo quello del dentifricio di colore verde. Lo trovi nei Brico center. E' un metodo economico che da un risutato a mio avviso buono.
