Codici sblocco menu E90
Discussion in 'BMW Fai da te e tutorial: trucchi e consigli' started by Davide, Sep 12, 2005.
  1. Davide
    25,219
    484
    Apr 20, 2004
    130i E87
    ho trovato questo in rete, ma non sapendo bene l'inglese, lo lascio a voi :lol:
    ____________________________________________________________
    I've got 2 questions for you:
    1) I read a trick on the MT web site to unlock the BMW menu.
    I would like to know if some had tested it ? and if yes, what arrived ? and how to relock the menu.
    here is what I read:
    For 'navigation' in the menu's, use the 'mileage reset button'.
    To get IN the menu's push that button for approx. 15 sec.
    Keep it pressed until you get the "01.__" in the display between the RPM and speedo-meter.
    "XX.YY" means the menu-numbers.
    If you want increase the "XX" part, push the 'mileage reset' button for approx. 2 sec.
    As soon as you see "XX.__", you can increase XX by pressing the 'mileage reset' button.
    Every 'push' increases "XX". If you want to increase the "YY", when the display shows,
    for exmaple "01.00", then every 'push' on the 'mileage reset', will increase the "YY" value.
    01.00 FGSTNR = "Fahrgestellnummer" (Chassisnumber)
    01.01 K-ZAHL W/T
    01.02 BMWTNR
    01.03 COD DIA
    01.04 KI HSTL DATUM = "Herstellungs Datum" (Manufactored/Essembled on date...)
    01.05 ???
    01.06 SW
    01.07 KODIERDATEN
    01.08 CAN
    02.00 KI TEST = Dashbord test. All light, gauges, displays and so on will light up,
    move.... works only when the engine is NOT running.
    03.00 ??? (maybe it will show something after your first 'service', motoroil change)
    04.00 MOM VBR = actual fuel consumption
    04.01 RW-VBR-MOM = fuel consumption per hour
    05.yy average fuel consumption
    06.00 how much you have in your 'tank' in liters. Left- and Right compartment and Total
    06.01 dito in hex?
    07.00 KTMP-MOM = Temp. Cooling Fluid (celcius)
    07.01 ATMP-MOM = "Aussentemperatur" Temp. Outside (celcius)
    07.02 dito in hex?
    07.03 N-MOT-MOM = RPM
    07.04 N-VWF-MOM = max. RPM at the moment. E60 it gives a vlaue. E90 it shows "-----"
    08.00 V-EFF = exact speed
    08.01 V-ANZ = "Anzeige" speed shown on dash..
    08.02 V-SZ
    08.03 D-GESCHW 1 WEG
    08.04 D-GESCHW 1 ZEIT
    08.05 D-GESCHW 2 WEG
    08.06 D-GESCHW 1 ZEIT
    09.00 Voltage
    10.00 KM/WOCHE
    11.00 ??? , has to do how the time will be displayed
    11.01 km or miles
    11.02 Celcius or Fahrenheit
    11.03 how to display fuel consumption. km/l or l/100km or mpg
    12.00 V-ANKUNFT = arrival time 12.01 ANK-ZEIT = time of arrival
    13.00 AUDIO = all(?) sounds. Like the 'boing' of the 'light on warning'
    14.00 FS EINTRAEGE = error messages (if any)
    15.00 Oil temp??
    16.00 Dashbord lighting.
    17.00 Temp inside in the car??
    18.00 CC-TEST = you can see some of the 'check control' messages.
    Look also at the iDrive screen!
    19.00 UNLOCK
    20.YY to 23.YY ???
    That UNLOCK stuff is also important.
    If not UNLOCKed, you can only see menu's 01 and 02.
    In the '19' menu you must 'click-in' a unlock code.
    That code you can calculate from the "FGSTNR" number.
    You must add the last 5 figures of that FGSTNR number. for example:
    : XXXXXX12345 the unlock code will be: 1+2+3+4+5=15
    20.YY to 23.YY There is more to discover......
    2) I have the iDrive with 8"8 screen but not the TV option. I would like to know if it is possible now to add the TV option easily (of course it would have been better to choose it at the beginning )
    Thank you by advance for your answers
    _____________________________________________________________
