CIP 20.01.00 Novità
Discussione in 'BMW Serie 5 E60-E61' iniziata da Riccardo, 25 Gennaio 2006.
  1. Riccardo
    Riccardo Direttore Corse
    1.870
    24
    6 Aprile 2004
    530e G30
    Nuovo bollettino rilasciato oggi da BMW.
    (In pratica serve solo per chi ha M5 E60)
    Riassume anche alcuni bachi corretti dalla 20.00 rispetto alla 19.xx
    SI B 61 14 03
    General Electrical Systems January 2006
    Technical Service
    This Service Information bulletin supersedes S.I. B61 14 03 dated December 2005.
    SUBJECT
    MODEL
    E60, E61 (5 Series)
    E63, E64 (6 Series)
    SITUATION
    Customer may complain of the following:
    The following software errors were corrected with the release of Progman 20.01.00 (Target data Status E060-05-12-510).
    While driving, the SMG control module switches to emergency program. SMG Fault Code 5101 (Hex) "Analyze hydraulic sensor" is stored. (E60 M5 only) Refer to SI B23 01 06.
    Check Engine Light is on, DME FC "2F4F vehicle speed plausibility" (N62TU only).
    The following software errors were corrected with the release of Progman 20.00.00 (Target data Status E060-05-12-500).
    Poor Idle quality after a cold start. N62TU engine.
    Engine juddering/idle speed surging when it is cold. N52 engine.
    Engine pinging under light load. N62TU engine.
    After programming the CID (Central Information Display) using Progman V19.x, the CID is blank and fault "A469 Internal Electronics Failure" is stored. Progman 20.00.00 prevents this programming failure. If the fault already exists the CID needs to be replaced.
    The following software errors were corrected with the release of CIP 19.02.03 (Target data Status E060-05-09-535).
    No software corrections included in this version of CIP
  2. paccagnella
    20.809
    1.503
    3 Maggio 2005
    Riccardo, se ti dico che non c'ho capito quasi un c....o mi credi?? E dire che l'inglese lo mastico decorosamente.... :-k :-k :-k
