BMW X3 G01 BIMMERCODE - Profili di guida
Discussione in 'BMW X3 G01' iniziata da antr6, 10 Novembre 2021.
  1. antr6
    antr6 Secondo Pilota
    838
    91
    10 Settembre 2018
    Ravenna
    BMW serie 4
    Smanettando un pò con bimmercode, ho visto che c'è la possibilità di impostare un profilo di guida prescelto ad ogni riavvio dell'auto.
    Alle tre voci (sport, eco e comfort) ne è presenta una quarta "adaptive"..
    sapete dirmi a cosa serve? non sono riuscito a capirlo.
    Credevo fosse la memoria dell'ultimo stile utilizzato, ma non è così.
    Ultima modifica: 11 Novembre 2021
  2. antr6
    838
    91
    10 Settembre 2018
    Ravenna
    BMW serie 4
    The "ADAPTIVE" mode is used for the first time in the BMW 7 Series. It is designed to achieve a balanced driving mode where the setup is automatically adapted to both the driving situation and the driving style.
    In this mode, the parameters of the Electronic Damper Control (VDP), the Electric Active Roll Stabilization (EARS), Electronic Power Steering (EPS) and the automatic transmission, for example, are switched between "COMFORT", "SPORT" and "ECO PRO" settings depending on the driving situation. However, when "ADAPTIVE" mode is active, no changes that restrict comfort (seat heating, A/C settings, etc.) are made in the event of switching to "ECO PRO" mode.
    "ADAPTIVE" reacts to the current driving style. The affected control units can change their parameters on the basis of the detected driving style.
    With the navigation system, the mode makes use of the available map data and optimizes "ADAPTIVE" Mode by predictive functions such as early reaction to bends, junctions and road type.
    The displays on the instrument cluster and Central Information Display (CID) remain in normal" mode and do not continuously change between "COMFORT" and "SPORT" modes. This is to prevent the driver from being distracted or lose comfort by changes in the displays. "ADAPTIVE" mode changes the modes in the background so that the driver does not notice the changes directly.
    The following influences on the driving style are taken into account, among others:
    • Longitudinal dynamics
    • Current speed
    • Pedal sensor position
    • Cruise control (sensor data from ACC radar sensor)
    • Sport shift gate for automatic transmission
    • Turn indicator
    • Steering wheel movements
    • Navigation data
    Informazione estrapolata da altro forum straniero e sembrerebbe che la modalità "ADAPTIVE" serva per ottenere una modalità di guida equilibrata in cui la configurazione si adatta automaticamente sia alla situazione di guida che allo stile di guida rilevato al momento.
    Altresì, sembrerebbe ancora, che si interfacci anche con il sistema di navigazione utilizzando i dati cartografici disponibili.
    I display sul quadro strumenti e sul Central Information Display (CID) rimangono in modalità "normale" e non cambiano continuamente tra le modalità "COMFORT" e "SPORT". Questo per evitare che il conducente venga distratto ovvero cambia le modalità in background in modo che il conducente non si accorga direttamente dei cambiamenti.
    Bah, avendola attivata, devo farci più caso.. vi aggiorno
