BMW Serie 3 E90/E91/E92/E93 Attenzione con emulatore ELV...
Discussione in 'Meccanica ed elettronica BMW' iniziata da bixiomauri, 16 Marzo 2019.
  1. bixiomauri
    4.985
    1.788
    21 Novembre 2016
    Emilia Romagna
    BMW 3 series E90 LCI
    Riporto solo quanto letto in un altro forum EN, e se cosi fosse (non ho questo problema per cui non lo uso) occhio a montare l' emulatore ELV senza PRIMA aver disconnesso il motorino originale dell' ELV!
    ATTENTION! Disassembly your ELV before putting ELV emulator!
    Please listen carefully and also please mark this thread as important. I could die, because of what happened to me today.
    I put the ELV emulator yesterday. My ELV wasn't faulty, but I had situations at the past that my battery was completly down and had to reset it all the time. So, I decided to put the emulator and say goodbye for the problem.
    Today after about 20km from my origin, while I was overtaking the vehicle, my steering wheel just locked and I tried to stop the car and I stopped, but on the tree... . I didn't suppose that's even possible. Never heard about locking the steering while driving, but YES, it's possible.
    After few minutes I connected the plug to ELV again and steering wheel lock went off, then I could tow the car to my garage.
    What's the instruction of ELV emulator installation? Plug&Play. IT'S NOT TRUE.
    The EVL emulator, was born to replace the EVL electric motor, ..
    many vendors do not indicate in the procedure the removal of the EVL engine, because they assume that using this emulator the EVL engine does not work (and therefore it is removed), this teaches that you can not take anything for granted, when it comes to security.
    Remember to disassembly your ELV completly before putting emulator, because otherwise you can pay your life.
  2. mcgiver68
    mcgiver68 Kartista
    71
    20 Gennaio 2008
    BMW 320D E90 Motorsport
    Possibile che questa ipotesi possa essere vera?Dal momento che si collega l'emulatore ELV il motorino del bloccasterzo non è alimentato, come può azionarsi in questa condizione?Sono in procinto ad effettuare la modificata,chiedo delucidazioni a chi ha già effettuato questa modifica.Grazie a tutto il forum
  3. Duffbimmer
    Duffbimmer Kartista
    50
    25 Febbraio 2021
    Siciloa
    E90 163cv
    Giusto, una volta inserito l'emulatore nei pin del piantone come fa ad essere alimentato il motorino Elv?
  4. bixiomauri
    4.985
    1.788
    21 Novembre 2016
    Emilia Romagna
    Forse per qualche motivo strano ( essendo rotto al 99% l' ingranaggio interno al blocco motorino e non bruciato il motorino stesso) pur non essendo alimentato, potrebbe far scattare l' azionamento meccanico del perno che blocca lo sterzo,magari in concomitanza di situazioni di angolo di sterzata particolari...ipotesi....
    In ogni caso terrei a mente i consigli di chi "scrive" di aver avuto l' inconveniente....che se effettivamente succede, può costarti la vita se in quel momento stai guidando.
    A german piace questo elemento.
  5. Duffbimmer
    Duffbimmer Kartista
    50
    25 Febbraio 2021
    Siciloa
    E90 163cv
    Si certo quando te ne accorgi è tardi :sgrat, è probabile come dici tu che era proprio l'ingranaggio rotto in quel caso, quindi in caso di solo errore ma meccanica ok l'unica soluzione senza spendere 1000€ sarebbe questa. Ma tramite ISTA si può aggiornare la cas di un e90 2.0 m47 2006 alla versione 29.1 come indicato da @atd1963? Da dove prendo i file di aggiornamento?
