2° gruppo d'acquisto dynavin e46/e39/e38/e53
Discussion in 'Compro' started by Diego89rsm, Apr 24, 2010.
  1. Oberon
    Oberon Kartista
    157
    e46 325 ci
    comunque sul sito http://www.e46fanatics.com/forum/showthread.php?t=731767
    c'è una faq e dicono no cdc e NO Names RDS
    bho?!?
    Update: Adding Q/A put together by Blue442 for the cliff's notes:
    Q: Do you have full ipod control correct?
    A: Yes
    Q: Does it has tv reception?
    A: Yes. You'll need to grab an antenna off ebay or such. Tuner is built in though. Not sure if it will work in the USA on the new digital standard.
    Q:dvd's play no problem when you are driving?
    A:Yes. You have to ground the parking brake wire, just like on any other DVD setup. It even tells you how to in the instructions.
    Q: Do Navi maps work fine when ipod or something else is playing?
    A: Yes
    Q: Do Album cover's of the songs show up on the screen when in iPod mode?
    A: No, it does not
    Q: What Maps are included?
    A: USA and Canada, iGo map updates can be purchased online for about $50
    Q: Do Steering Wheel controls work?
    A: Steering wheel controls work for radio/dvd/ipod/cd. Climate control works fine. Everything works like OEM, however lack of steering wheel control for Bluetooth
    Q: Is the CD Changer Compatible?
    A: No, it is not.
    Q: Can you play Ipod Video?
    A: Yes
    Q: How many Aux ports are there?
    A: unit has 2 aux in ports
    Q: Where is the Mic
    A: The unit comes with a built in mic on the unit (lower left corner) and a wired external mic. Seeing as i have a vert, I put it in the upper corner of the windshield with the wire running up the A-pillar. It's quite hidden. If you have a coupe, there's plenty of wire to mount it in the factory location. The mic just uses a standard 3.5mm jack, so if the BMW[​IMG] factory one has that, you could plug the factory mic into the unit.
    Q: How does Bluetooth work?
    A: Bluetooth is controlled 3 ways.
    You dial on the phone and once you hit send, the stereo picks it up and switches over to the bluetooth screen on the unit.
    You touch the screen and return to the home screen and then click bluetooth. Then you use the dial pad on screen or use the phonebook feature on the screen.
    You press the large button in the lower right corner of the unit. It takes you to the bluetooth screen. Then you use the dial pad on screen or use the phonebook feature on the screen.
    Q: Does Satelite Radio work?
    A: If you have a tuner that uses RCA and you can pluig it into the AUX in.
    Q: Where is the ipod connector located?
    A:in the back or the front? in the back, but it comes with a cable so you can place it where you want
    Q: Does this required the use of the AC Relocation Kit?
    A: Yes, you can get it from tischer
    http://www.trademotion.com/partlocat...&siteid=214672
    Here are the part numbers
    http://forum.e46fanatics.com/showpos...31&postcount=4
    51 16 7 001 410 (illuminated)
    51 16 7 001 408 (not illumincated)
    Q: Does this require cutting into the AC Ductwork?
    A: No
    Q: Do i need to use DICE with this system?
    A: No
    Q: Would the unit allow for firmware upgrades if the unit had bugs, and Dynavin released updates?
    A: Yep. They said that they will periodically release firmware updates that can be loaded on a USB memory stick or on the microSD card and installed.
    Q: Can you play avi/divx files off of the sd card or memory stick as well?
    A: Yes, off the memory stick. Have not tested with SD card.
    Q: Is it possible to get "names" on the radio channels, or does it just display the frequency?
    A: No, no names
    Q: how does the ipod integration work. will i be able to swich songs on the steering wheel?
    A: Yes. And volume control too.
    Q: Does BMW Assist continue to function or will we loose that functionality?
    A: No idea. I don't have BMW assist to test.
    Q: Is it possible to make the built in microphone work with this unit?
    A: Anything's possible. The unit uses a standard 3.5mm jack, so if you can wire the stock mic to a plug like that, then it should work.
  2. mazz_mg
    mazz_mg Collaudatore
    458
    24
    Mar 7, 2008
    430i Msport
    ti propongo io una bella prova, vieni da me e te la faccio vedere, abbiam 45minuti di strada (senza traffico) :biggrin: se ti va volentieri, basta che non me la vuoi smontare per vedere gli attacchi dietro :mrgreen: che proprio non ne ho voglia!!
  3. Oberon
    Oberon Kartista
    157
    e46 325 ci
    si me lo ha proposto anche diego.
    molto gentili entrambi
    possiamo anche incontrarci
    quando ci 6?
    non abiti lontanissimo
    non lo farei smontare enanche al mio peggior nemico
  4. gighen78
    gighen78 Kartista
    95
    mg
    io sono la persona in questione , quindi mi sento chiamata in causa!
    a parte il fatto che discutere sulle altre persone non mi pare di buon gusto, comunque la garanzia è di 2 anni con centro assistenza nel triveneto (con il quale collaboro)
    dynavin si trova in cina cosi come a taiwan cosi come in germania, quindi attenzione a quello che si dice!
    io collaboro con dynavin taiwan e lavoro come referente per l'italia
    il resto è aria fritta
    sto vendendo ora su ebay le radio ceh sono finalmente disponibili!
    il resto sono chiacchiere da bar ( vi aggiungo un altra cosa importante: la dynavin vuole che i rivenditori stiano sui 700 euro a pezzo...)
    se siete interessati a un ordine multiplo delle ultime versioni contattatemi
    alessandro
  5. Silverice
    Silverice Amministratore Delegato BMW
    3,539
    72
    Sep 14, 2005
    Milano
    Z4 3.0 -330Ci -Tiguan Rline (Ex e36-e30)
    se pur fuori dalla diatriba :rolleyes: mi spiace come si sia evoluto il discorso 2din...
  6. Diego89rsm
    Diego89rsm Presidente Onorario BMW
    5,526
    162
    Feb 20, 2009
    ///m e46 cabrio
    è anke vero che qui la gente si crea problemi per niente comunque!!!!
  7. gighen78
    gighen78 Kartista
    95
    mg
    No tutto chiarito..ognuno porta acqua al suo mulino!
    importante è che quello che si vende sia valido
    Comunque ho un compromesso anceh con le hualingan, per cui se siete interessati alle huanligan posso avere totale anche da loro
  8. seven.b
    seven.b Kartista
    202
    bmw 320ci exM3 ex320ci ex320d
    Quindi si chiude il gda.....!!!
  9. BMW_4_ever
    BMW_4_ever Kartista
    240
    Per chi è interessato veramente mi contatti visto che i GDA non è possibile concluderli....
  10. ilbmwista
    ilbmwista
    26,623
    1,360
    Dec 9, 2008
    Bmw 320ci E46///M
    io sono disposto per un gda, ma con calma, anche dopo l'estate l'importante che facciamo numero e che il prezzo scenda!
  11. Alessandroguitarsound
    9,839
    570
    May 31, 2008
    bmw 330d m-paket
    son con te...ciao carissimo...:wink:
  12. andrea_gt85
    andrea_gt85 Aspirante Pilota
    30
    Bmw 320d 150cv
    Scusa se mi permetto. ma visto che sei con lui quando organizzerete un altro GDA a suo tempo farete un altra discussione e chi sarà interessato Vi parteciperà.
    Credo si sia arrivati già oltre il limite da un pezzo con questo forum.
  13. Alessandroguitarsound
    9,839
    570
    May 31, 2008
    bmw 330d m-paket
    non ho capito cosa intendi?:-kcosa ti turba?:-k
  14. Alessandroguitarsound
    9,839
    570
    May 31, 2008
    bmw 330d m-paket
    allora?mi spieghi cosa volevi dire con quel post?
  15. ilbmwista
    ilbmwista
    26,623
    1,360
    Dec 9, 2008
    Bmw 320ci E46///M
    :wink:
  16. ilbmwista
    ilbmwista
    26,623
    1,360
    Dec 9, 2008
    Bmw 320ci E46///M
    Tranquillo non sto mica dicendo che tutti dovrete fare come penso che sia meglio (a mio parer) ognuno è libero di fare cio che vuole! ;) /emoticons/wink@2x.png 2x" width="20" height="20" />
  17. Stefano 63
    Stefano 63 Secondo Pilota
    642
    Sep 30, 2009
    BMW 318 ci E 46
    Ciao a tutti, cambiando argomento volevo chiedere se è difficile montare la retrocamera e se bisogna smontare qualcosa. Grazie.
  18. mazz_mg
    458
    24
    Mar 7, 2008
    430i Msport
    Sicuramente qualcosa, conta che va dalle parti della targa, quindi devi passare con il cavo video dal baule alla macchina insieme alle altre connessioni originali (nel cavo di gomma nero grosso per intenderci che porta i cavi al baule), poi devi arrivare fino alla radio, dovrai sicuro smontare i sedili dietro per passare, poi io sono riuscito ad infilare il cavo pre del sub nelle plastiche che sono a terra vicino alle porte, senza smontarle, ma quando arrivi davanti devi salire nel cruscotto ed arrivare dietro laradio...poi oltre a questo devi arrivare fin li anche con un altro filo che parte dai fanali posteriori (le luci di retromarcia), è il comando che accende la telecamera....poi devi smontare la radio se l'hai già montata...insomma c'è da divertirsi non poco :wink:
  19. MauCec
    MauCec Aspirante Pilota
    19
    ex 330d e92
    Sono arrivate le unità 3g?
  20. gighen78
    gighen78 Kartista
    95
    mg
    le 3g (il dongle 3g ) viene 80 euro supplementari
    come detto in messaggio privato il prezzo per 5 pezzi è stato gia fatto..
