Info Gran Coupè 428i M-Sport
Discussione in 'BMW Serie 4 F32 / F33 / F36' iniziata da Ale77SBT, 14 Ottobre 2014.
  1. Gio72
    Gio72 Presidente Onorario BMW
    28.985
    2.941
    3 Giugno 2008
    G80 M3 Competition
    @smg ce l'ho fatta! Ho trovato quella benedetta intervista, che riporto integralmente evidenziandoti la parte relativa alle sospensioni della F32, la cui altezza appunto è identica per assetto standard e assetto M:
    July 24, 2013
    We recently asked for your questions regarding the BMW 4 Series and we brought those (together with some of our own) to the drive launch for the F32. Big thanks to all the gracious BMW representatives who patiently answered our questions.
    Here's what we were able to find out for BIMMERPOST members.
    Are there suspension or steering tweaks/improvements in the F32 compared to the F30?
    The F32 is much more rigid than the F30. One way BMW has done this is by using a different suspension with extra V- or X- bracing from the subframes going back to the car's chassis. Also, the entire suspension is different from the F30. We know this car will be mostly driven with two people aboard and in a sporting way. Therefore, we have tuned the suspension for the performance minded driver who needs a coupe that can hold four people occasionally. BMW has tested its competitors car's chassis, and we (BMW) have the highest torsional rigidity in this class of car.
    The F32's electric power steering has different programming to allow for a sportier experience.
    How do the lower center of gravity and other suspension tweaks impact handling specifically?
    While it's not something you can really feel, it's something you CAN measure. In a slalom or emergency lane change maneuver, it can be measured. The F32 is about 0.5 mph faster in a slalom (than the F30) and the car is more stable under a emergency lane change because the center of gravity is much lower than that on a F30.
    Does the coupe still have sport suspension as standard?
    No. It really was not standard on the e92 either (only initially when the car first launched). The F32 will come with a standard suspension, with two dynamic settings: Sport and Comfort. M Sport cars will have the same ride height as the standard suspension -- this is something new. Also, xDrive models will have a slightly higher ride height due to their use for driving on snow and ice.
    Does the xDrive suspension on the 4 series have the same calibration as the F30's xDrive suspension calibration?
    No, the F32 suspensions are all new in their tuning/damping.
    Why is the xDrive version of the 435i faster than the non xDrive version, yet the same is not so for the 428i compared to the 428i xDrive?
    Well... xDrive only adds about 70Kg's of weight to the car. And it really aids in low traction situations... so it should be no wonder why a car would be faster in acceleration from a stand still than a 2 wheel drive car. But, it should be noted that xDrive does add some weight where you really do not need added weight - in the nose of the car. This is why the M brand has deemed it less than "pure" for use in M models. But, for people who live in snowy areas... this is an acceptable trade-off for added traction in winter conditions.
    How much more rigid is the 4 Series chassis than the E92 3 Series Coupe?
    It is 60% more rigid, due to the use of added suspension cross bracing on the front and rear subframes linking the suspension with the car's chassis. We spend a lot of time on this - making the two door coupe stiffer.
    How do the times around the Nurburgring compare to a similarly configured F30?
    The coupe is faster than the sedan, but we do not have any 'Ring lap times to give you in terms of xx time vs yy lap times. We can say the F32 coupe is faster than the sedan due to the above mentioned chassis improvements.
    Can we expect a M435i model in the future?
    No plans of yet.
    Any possibility for DCT transmission in the future?
    No. The DCT will be for M models. The latest eight speed ZF automatic shifts so fast and cleanly, we do not see the need for a DCT.
    It was rumored last generation that the coupes would form the 4 Series, but it was scrapped. What was it that made it happen this time around?
    Not really my dept... so I can not answer as to why now. But, back then we did not have a X6 nor a 6 Series Gran Coupe, so the even numbering is fitting in with our model hierarchy. I think it makes it easier for the customer to know an even number is a coupe (or coupe-like) form and that odd numbers are our sedan models.
    Any particular reason for the hood cutline position being in the middle of the hood instead of where it joins the grilles? Is there a technical reason for it?
    There are a lot of reasons why, but mostly it is for pedestrian crash rules here in the EU and in the USA. We have to have "soft" areas in the front of the car and the only way to do this is to have that "cutline". We even make the hood of the car "softer" or more "friendly" to pedestrians impacts and design preformed crush areas of the hood for EU or US crash standards. But it's all a compromise, so we try to build a car that can meet all the modern day requirements today's car must me[/b]et and excel in.
    Ultima modifica di un moderatore: 17 Ottobre 2014
  2. smg
    smg Kartista
    130
    12 Ottobre 2005
    420xd msport GC (ex-330xd touring)
    ok Gio, :lol: mi arrendo.. ](*,)
    esco ora dalla concessionaria per far sistemare sto benedetto ampli (ora collegato correttamente)
    ho parlato con i meccanici, me ne dicono una nuova..che sulla serie 4, sopra un determinato valore di kw montano le sospensioni Msport anche per le verisioni standard
    alzo le mani..
    approposito, mi dicono che l'ASD è compatibile solo con il 435d, ormai però dubito su tutto, dovresti dare il telaio in concessionaria per vedere la compatibilità dell'accessorio
  3. Gio72
    28.985
    2.941
    3 Giugno 2008
    G80 M3 Competition
    No, no, se vai su Realoem.com e cerchi gli accessori audio per la 435i troverai pure l'ASD... E scommetto (ma non ho verificato) che invece non ci sia per 435d.
    Quella dei kw mi giunge totalmente nuova e mi pare anche poco sensata... Ormai comincio a pensare che in certi concessionari facciano ampio uso di sostanze stupefacenti :D /emoticons/biggrin@2x.png 2x" width="20" height="20">
  4. Gandalfilbianco
    Gandalfilbianco Aspirante Pilota
    18 Maggio 2014
    BMW 428i MSport GC
    ciao, sono un neo-proprietario di una GC 428i, quindi proprio il modello che desidereresti.
    E' ancora presto per darti un parere "definitivo" (sono solo a 1400km), ma intanto posso dirti che:
    - le sospensioni adattative sono fantastiche, in confort sono comodissime (ancor più dell'audi A5 SB che avevo in precedenza)
    - il motore è molto lineare (come detto anche da Alba428), ma secondo me comunque piacevole (anche se ancora non l'ho tirato a dovere) se si vuole spingere e sufficientemente elastico da non farmi rimpiangere troppo il 6 cilindri diesel della mia vecchia E92. E poi occhio al tachimetro perchè sali di velocità senza rendertene conto, merito anche del superbo cambio automatico 8M sport
    - il sound: qui ho letto molti pareri negativi, secondo me non è poi così male... sì, sembra un pò "castrato" (dovuto probabilmente al grande lavoro di insonorizzazione fatto dagli ing. bmw) ma comunque di sonorità piacevole (ovviamente imho)
  5. Ale77SBT
    Ale77SBT Kartista
    151
    14 Ottobre 2014
    X6 3.0d Extravagance
    Per il sound allo scarico si può ovviare montando terminali sportivi Remus o Supersprint.
    L'importante è che il motore spinga già dai bassi regimi.
    Io sono indeciso se ri-affidarmi al cambio automatico (dopo la non esaltante esperienza del 7g tronic mercedes) o se ritornare al vecchio caro cambio manuale.
    Credo infatti che per godere il massimo della sportività, anche il buon 8M sport non sia il massimo.
    I cambi automatici montati sulle auto di questa categoria saranno comodi ma non potranno mai a mio avviso dare la stessa "soddisfazione" di un buon manuale....
    Cosa ne pensate?
  6. Elicablu
    Elicablu Secondo Pilota
    792
    414
    16 Febbraio 2008
    EX 530d xdrive Touring g31
    ....se hai già provato uno step 8 sport ti sei già risposto, altrimenti provalo e vedrai...si avvicina a un doppia frizione che non ti immagini.... Ovviamente imho
  7. smg
    smg Kartista
    130
    12 Ottobre 2005
    prova l'8m...
    il 7gtronic in confronto ti sembrerà una lavatrice
  8. smg
    smg Kartista
    130
    12 Ottobre 2005
    e dire che in confronto a quelli Audi mi sembravano preparati.. ;) /emoticons/wink@2x.png 2x" width="20" height="20">
  9. Gio72
    28.985
    2.941
    3 Giugno 2008
    G80 M3 Competition
    Il 7g tronic sta allo step8m come Rosy Bindi sta a Belen!
    Scherzi a parte, il 7g tronic è un discreto automatico, lo step8m è un automatico eccezionale, che in uso manuale è al livello dei migliori doppia frizione. Dico dei migliori, perché, giusto per restare in casa MB, il doppia frizione della A45 è certamente inferiore allo step8m, come ho avuto modo di appurare direttamente ;) /emoticons/wink@2x.png 2x" width="20" height="20">
    E' una bella lotta...
  10. Gio72
    28.985
    2.941
    3 Giugno 2008
    G80 M3 Competition
    A proposito, invito a considerare per lo scarico della 428i quello M Performance: ricordo che lo montò [MENTION=42217]captain_caveman[/MENTION] sulla sua 328i e migliorava notevolmente il sound, con piacevoli borbottii in rilascio ;) /emoticons/wink@2x.png 2x" width="20" height="20">
  11. Ale77SBT
    Ale77SBT Kartista
    151
    14 Ottobre 2014
    Come Sound quello del 6 cilindri 435i è di un altro pianeta
    Con uno scarico serio tipo Akrapovic poi sembra una WRC più che un' auto stradale
    Certo che quasi 8'000€ di differenza di listino fra la 428 e la 435 non sono pochi.
  12. Gio72
    28.985
    2.941
    3 Giugno 2008
    G80 M3 Competition
    Ti dirò, hai ragione, non sono pochi, ma per me la differenza tra N20 e N55 è sostanziale.
  13. Ale77SBT
    Ale77SBT Kartista
    151
    14 Ottobre 2014
    A vs avviso fra 4-5 anni l momento dell' acquisto di un'auto nuova è plausibile aspettarsi anche una svalutazione maggiore del 435i rispetto al 428i?
  14. Vociferous
    Vociferous Collaudatore
    271
    23
    22 Febbraio 2014
    Da Bmw 435i M Performance a Cayman 718
    Confermo pienamente la tua tesi... ;) /emoticons/wink@2x.png 2x" width="20" height="20">
  15. Gio72
    28.985
    2.941
    3 Giugno 2008
    G80 M3 Competition
    Per forza. L'AUTOlesionismo italico non ha limiti...
  16. Ale77SBT
    Ale77SBT Kartista
    151
    14 Ottobre 2014
    Ultima modifica di un moderatore: 9 Novembre 2014
  17. Gio72
    28.985
    2.941
    3 Giugno 2008
    G80 M3 Competition
    @bimbo320 se li è fatti fare (di tonalità simile) da una conceria artigianale: risultato IMHO stupendo il suo!
  18. bimbo320
    9.022
    287
    15 Ottobre 2007
    BMW F10 520d Toyota Verso S
    Quelli in foto dovrebbero essere gli Individual Amaro Brown.....
    Effettivamente il mio e' molto molto simile eccetto per il bordino di pelle bianca ribattuta che a dire il verno non mi entusiasma granché...
  19. Ale77SBT
    Ale77SBT Kartista
    151
    14 Ottobre 2014
    Credo sia Gold Brouwn.; L'amaro è più "marrone"
    Il fatto è che non lo trovo ne sul catalogo ne sul sito della serie 4 ed ovviamente non è configurabile
  20. Ale77SBT
    Ale77SBT Kartista
    151
    14 Ottobre 2014
    Anzi mi correggo; avrei trovato sul configuratore ma mi mostra solo i sedili e le portiere in pelle e non il sotto plancia... come mai?
    Inoltre se scelgo questo tipo di rivestimento "individual" il configuratore non mi permette di selezionare ne la versione "Sport" ne la versione "M-Sport" (solo la Luxury)
    Mi sembra di ver letto però che nella realtà si dovrebbe potere abbinare questo rivestimento ad una delle due versioni "sportive"
